Electric water pump testing?
Old Aug 31, 2005 | 11:12 AM
hambone3441's Avatar
Is it ok to connect directly to the battery with a CSR electric waterpump for a few seconds to test the clearances in the housing prior to installing on the motor?
Rob
Old Aug 31, 2005 | 12:08 PM
JasonK94Z's Avatar
Re: Electric water pump testing?
Yes. I did that to minelast night, but after I had everything mounted back up.
Old Sep 3, 2005 | 09:14 PM
96trans am's Avatar
Do you guys have any idea how fast they spin. I have a Meziere and bought it from a guy on here and mine moves slow as s*it. Ive asked around and im not sure if this is how everyones spin or i was sold a defective one. Thanks. -Matt
Old Sep 3, 2005 | 09:18 PM
NVetro's Avatar
I would like to know if I can do this also, I want to do it tomorrow...
Old Sep 3, 2005 | 09:22 PM
I tested mine out the other day and it seemed to spin fairly fast and smooth. Dont have any idea on an actual speed but it looked normal.
Rob
Old Sep 3, 2005 | 11:50 PM
ZMAN Z28's Avatar
Call Mezire or CSR, they both should run at similar speeds. They probably won't be open till tuesday.
Z
Old Sep 3, 2005 | 11:53 PM
snakethis69's Avatar
i hooked mine up to the battery in the housing to test clearance. but before i did i had the thermostat out and tried pushing the blades by hand, they wouldnt move to i knew i have some clearancing to do. fixed the problem then hooked it to the battery for about 5 seconds, mine spins pretty fast.
Old Sep 4, 2005 | 10:12 PM
NVetro's Avatar
I tested mine earlier today. Just connected the black wire to ground and blue wire to positive on my optima red top battery. She spun pretty decently fast, no grinding issues or anything, clearences seem good to me. Awsome way to test it though, never thought of that haha i thought it would screw up the pump if fluid wasn't present or being moved, i was wrong. Worked out well
Old Sep 4, 2005 | 11:34 PM
96trans am's Avatar
Take a video so i can see how fast it should spin. PLEASE lol.
I really need to see this cause mine cant be right. Thanks. -Matt
Old Sep 5, 2005 | 07:40 AM
cehan's Avatar
Not a good idea to run any pump with a mechanical seal dry for very long. Mechanical seals are lubricated by the fluid that is being pumped and you could damage the seal faces.
Old Sep 5, 2005 | 08:58 AM
NVetro's Avatar
A few seconds to test clearences should be fine though, just cant let her go and spin for 5min at a time without anything in her.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
Zone
Jul 29, 2002 07:43 PM
