Are these heads good for a blown 383?
Old Aug 30, 2005 | 03:44 PM
bluelt1z28's Avatar
I bought these heads from TPIS. They are AFR heads that are ported by TPIS. The intake runners are 187 and have a 54cc chamber. My engine is a LT1 383 with 9.3:1 compression and a 224/236 114lsa comp cams and I am using a procharger twin intercooled @ 8 psi.
Here is a link to my flowsheet. They were tested on a superflow 400 with test pressure 28 in. of water.http://www.xtremetransmissions.com/wst_page2.html . Just scroll down and you will see the flow sheet.
Here is a link to TPIS http://www.tpis.com/
Old Aug 30, 2005 | 04:30 PM
sssalah's Avatar
Re: Are these heads good for a blown 383?
Not bad for such a small intake runner, it would've been better if the exhaust flowed more for the SC but that cam should help with the nice split and small overlap.
Old Aug 30, 2005 | 06:45 PM
bluelt1z28's Avatar
I forgot to mention tha i am using 1.6 pro-mags
MadMav
Feb 6, 2015 11:02 PM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Nov 20, 2014 06:03 PM
