cooling system problem
Old Aug 29, 2005 | 11:06 AM
Everett's Avatar
Hello i have a cooling problem. My problem isent that the car overheats the temp runs normal but i smell coolent every now and then and cant find out where it is coming from? i checked the oil none in it there is no smoke what so ever coming out of the pips i put a piece of carboard under the car and all i get is a drop or two of oil nothing elese. i cant find the leak anywhere. i was thinking maybe the water punp or heater hose..
Thanks guys
Shane
Old Aug 29, 2005 | 11:20 AM
BUBBA's Avatar
Re: cooling system problem
Heater core?
Old Aug 29, 2005 | 02:09 PM
moparman's Avatar
Are you losing any coolant?
Old Aug 29, 2005 | 02:47 PM
Heater core would be my first guess. You don't need to have a puddle of coolant on the floor for it to be seeping and it's easy to smell.
Old Aug 29, 2005 | 05:26 PM
Everett's Avatar
Thanks guys i am not getting a puddle of coolent on the floor and am not loosing much coolent at all maybe a oint or so every couple weeks. it is enough to just drive a person mad trying to find where the leek is.
Thanks for the help
Shane
Old Aug 29, 2005 | 05:35 PM
Robs97Z28's Avatar
check the water pump weep hole. with a flash light and a floor jack you can see from under the car.
Magenta_Hearts
Mar 25, 2015 10:24 AM
grgguy
17
Feb 23, 2015 07:57 PM
kksi
Feb 17, 2015 10:41 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
