iac not moving
Old Aug 29, 2005 | 04:31 PM
sw89lt1's Avatar
iac not moving
i pulled the iac because the car was idleing at 2grand. so i pluged it into another car and it moved in and out. but when i plug it into my car and turn the key on and off it will not move at all. i checked all the fuses and reset the computer but still no luck. any ideas?
Old Aug 29, 2005 | 05:09 PM
turbo_Z's Avatar
Re: iac not moving
check the wiring and the plugin?
Old Aug 29, 2005 | 05:39 PM
sw89lt1's Avatar
Re: iac not moving
this all started after i put a piece of cardboard over the throttle bodie to lower the idle, just to see where i wanted the idle set at. but it would not run worth a crap so i pulled the card board off. when i pulled the cardboard off it went back to idle. the next morning i started it and it would not idle down.
which wires should be getting voltage?
Old Aug 29, 2005 | 06:08 PM
sw89lt1's Avatar
Re: iac not moving
checked all wires from the pcm connector to the iac connector. they all checked out good.
Old Aug 30, 2005 | 02:05 PM
sw89lt1's Avatar
Re: iac not moving
ttt
Old Sep 1, 2005 | 04:08 PM
sw89lt1's Avatar
Re: iac not moving
heeeeeellllllllllllp! what voltages should the iac be geting?
Old Sep 4, 2005 | 03:34 PM
sw89lt1's Avatar
Re: iac not moving
could the computer be fu(ked up? the car runs but it still won't move.
Old Sep 4, 2005 | 03:48 PM
Re: iac not moving
I would check it with a scanner to see what it is commanding the IAC to do.
Old Sep 4, 2005 | 03:55 PM
sw89lt1's Avatar
Re: iac not moving
brian is sending me a pcm as we speak. if its not something with the pcm i don't know what it could be. does the iac work off a voltage pulse or what?
Old Sep 7, 2005 | 02:49 PM
sw89lt1's Avatar
Re: iac not moving
put the other pcm in and it works perfect.WTF
any ideas?
Old Sep 7, 2005 | 03:17 PM
Re: iac not moving
any ideas?
I guess you have a bad computer. Put the other back in and see if it still fails.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
tdigger9899
Sep 7, 2015 10:56 AM
