Crankshaft pulley installation
My brother forgot how the pulley was positioned when he took it off. Does it matter how it is installed as far as the crankshaft being properly balanced. I thought it just mattered in telling tdc but i figured i would ask you guys.
Re: Crankshaft pulley installation
Its only for tdc reference. I've read if there are weights in the holes in the balancer then the direction matters, but it really doesn't make any sense. I wouldn't worry about it. If you have the time though, pull the #1 plug and verify TDC. Doesn't hurt to put it on correctly.
