Datamaster shows 11.9-11.6 volts at idle?
Old Aug 27, 2005 | 03:28 PM
93z383's Avatar
Is this reading accurate. I have an overdrive pulley for the alt, and underdrive on the crank....( I said crank) Could this be a alternator/voltage regulator issue....could this be why my water pump/temps are high?
Old Aug 27, 2005 | 04:06 PM
Re: Datamaster shows 11.9-11.6 volts at idle?
Take a reading at the battery with a meter at the same time you are monitoring with your software. I have seen some voltage drop through the ignition switch.
Old Aug 27, 2005 | 08:28 PM
89TramsAmGTA's Avatar
I agree about taking a reading at the battery. There is a good 1/2 volt if not more between what my battery reads and what the software says. This is on my 3rd gen.
ChrisFrez
Mar 1, 2015 01:33 PM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
ChrisFrez
Jan 4, 2015 08:43 AM
pete53
Dec 9, 2014 07:31 AM
