heat wrap
Old Aug 27, 2005 | 04:41 PM
benji's_z28's Avatar
Question heat wrap
i am replacing my plug wires with msd 8.0 mm wires since i fried a wire with my headers. i was wondering if putting heat wrap around the headers would protect the wires from getting fried again. or will the new wires hold up to the heat. thanks
Old Aug 27, 2005 | 05:11 PM
Re: heat wrap
Wrapping the headers is a bad idea. It's not good for the pipes and can be a fire hazard. Insulating your wires is the better choice.
Old Aug 27, 2005 | 07:56 PM
2000GTP's Avatar
Re: heat wrap
Also, alot of header companies will void the warranty if header wrap is used. Like stated above, your best bet is to get heat insulated wires and to route them away from the headers with either zip ties or go the route of a over-the-valve cover wire loom kit.
Old Aug 27, 2005 | 11:55 PM
n20ta2's Avatar
Re: heat wrap
I thought header wrap was flame retardant??? Anyways as mentioned its best to insulate the wires ,my experience with header wrap led to rusty headers after only 1 year of use.
Old Aug 28, 2005 | 12:06 AM
Re: heat wrap
The fire hazard is when its get dirty and oily.
Old Aug 29, 2005 | 09:12 AM
n20ta2's Avatar
Re: heat wrap
Ahh now that makes perfect sence!! I never had that problem though as the engine was leak free.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
n2oblkz
Oct 22, 2015 02:31 PM
CARiD
Sep 30, 2015 05:44 AM
damnyankee36
Sep 9, 2015 07:06 PM
