WHat kind of #'s do you think this would make..
Old Aug 28, 2005 | 11:06 PM
Bow94z's Avatar
a 355 LT1 with cc306, LE ported LT4 heads, Ported LT4 intake,52mm TB,30 lb injectors LT's True duals... im just curious
Old Aug 29, 2005 | 09:30 AM
SS MPSTR's Avatar
Re: WHat kind of #'s do you think this would make..
More than 300rwhp.
Old Aug 29, 2005 | 10:32 AM
tireburnin's Avatar
Originally Posted by SS MPSTR
More than 300rwhp.
Haha...damn that's funny. Best guess ever!
Old Aug 29, 2005 | 11:59 AM
JustNO's Avatar
390-400rwhp (I guess lloyd don't let you stay under 400rwhp)
Old Aug 29, 2005 | 01:27 PM
Steves396lt1
Guest
Posts: n/a
375rwhp.
Old Aug 29, 2005 | 05:51 PM
89385formula's Avatar
Well, I would say it could be from 370-400+ RWHP. Roadtrip or Kryckter just posted the other day about a setup with LT1 castings that was fairly similar, with the 306..and it made 400RWHP. I think it will depend more on what Stage the LT4 heads will be ported to.
Old Sep 15, 2005 | 01:32 PM
Bow94z's Avatar
do you think its worth keeping the stock heads and get them ported heavily, or go with some decently ported LT4 heads
Old Sep 15, 2005 | 01:57 PM
jkipp84's Avatar
The 'rule of thumb' I've seen here is stockers are good for 350/355 LT1s. AFR/TF heads are better suited to strokers.
If you do a search (I'm not being a smart ***, there's a ton of info), you should come up with your answer.
Old Sep 15, 2005 | 03:37 PM
How much ya wanna spend? The Stockers ported can support a pretty hefty amount of power with stock displacement. However if I had the funds, I would get some worked over LT4's. Remember the better the headflows the smaller the cam necessary to make power. Also, i would probably get a custom cam rather than a CC306. Basically the only difference in the combinations that Roadtrip and Kryckter posted looked to be the cams, Kryckters had the LE2 cam, and the other had the 306....417RWHP, and 400RWHP.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
Hal Fisher
Sep 30, 2015 09:03 PM
karpetcm
Sep 29, 2015 10:08 AM
