Can Anyone Help?
Old Aug 28, 2005 | 06:38 AM
miiso11's Avatar
Can Anyone Help?
Just installed UD crank pulley last weekend. The car started and ran great for a few miles until it just died. The belt was slipping and not allowing the alternator to turn at appropriate speed. It started right up again and I was able to drive it home by keeping the rpm's up enough to charge. Today, I swapped the belt for a shorter one and the car just will not start. I tried jumping it off of my Toyota thinking maybe the battery voltage was just too low. The battery is only about 2 years old. It cranks over fine. When I turn the key to the "on" position, I can hear the fuel pump pressurizing the system, so I don't think that it is that. Just did a tune up about 2 years ago, approx 1,800 miles since then.
Does anyone have any suggestions?
Old Aug 28, 2005 | 07:43 AM
Re: Can Anyone Help?
Why the identical threads?
http://web.camaross.com/forums/showthread.php?t=393054
Old Aug 28, 2005 | 08:45 AM
miiso11's Avatar
New to the forum and just hoping that someone would see it sooner if I posted again today.
Just rechecked everything this morning and there are no loose electrical connections or anything. Is there a crank position sensor on the 95 LT1? If so where is it and could this be the problem?
Old Aug 28, 2005 | 09:25 AM
Eff's Avatar
Eff
No. No CPS until 96.
So now it just keeps cranking or what? is it a slow crank
Old Aug 28, 2005 | 10:03 AM
miiso11's Avatar
When it is cranking, it sounds normal but just doesn't start. Normally it would start as soon as I would hit the key.
It is just strange that when I backed it in the garage, It would shut off and start just fine, just had to keep the rpm's up. The car sat for a week until I had a chance to get the shorter belt, and now it doesn't hit at all.
Old Aug 28, 2005 | 11:22 AM
miiso11's Avatar
Will a TPS keep the car from starting or a MAF sensor keep the car from starting?
I just sprayed starting fluid in the throttle body and the car started and died.
I had disconnected both of these sensors last week when I did the throttle body bypass. But the car ran after putting everything back together.
Any thoughts?
Old Aug 28, 2005 | 11:59 AM
Welcome to CamaroZ28.com
Please do NOT double post. You are asked to post a topic only once, then permitted to "TTT" it no more than once in a 24-hour period. TIA for you cooperation. The other thread has been deleted.
As far as your problem, is it possible the bolts you used to install the U/D pulley were too long and hit the Opti?
Old Aug 28, 2005 | 03:41 PM
miiso11's Avatar
Thanks Fred for your input, but I thought of that as well. The bolts clear the opti just fine. I know the car is getting spark, it is just not getting fuel. I went to Auto Zone to have the TPS tested and it is fine. I also bought the OBDII scanner, however, it gives me a link error. I have eliminated the scanner as being faulty because it works fine on my 97 V6 Camaro.
I even reinstalled the stock programming and the scanner still doesn't link up. Could it be the ECM? I wouldn't think so since I was able to use the Hypertech programmer to reinstall stock settings. Just curious.
I appreciate any comments or suggestions on where to go next.
Old Aug 28, 2005 | 03:51 PM
joeSS97's Avatar
Check to see if you have fuel pressure.It sounds like you dont...Can you hear the pump?
Old Aug 28, 2005 | 04:56 PM
chuckd4more's Avatar
The scanner probably didn't work because the 95 is not OBDII. It is OBDI with an OBDII connector. I know, it sucks.
Your 97 is, however, OBDII.
Old Aug 30, 2005 | 03:06 PM
miiso11's Avatar
yes I can hear the pump kick in and then kick off right before turning the key to "start". I seems kind of strange that the car would start and run with me revving the engine, sit for a week, then not start at all.
