Tightening polylocks
Old Aug 27, 2005 | 03:45 PM
Jazsun's Avatar
I have polylocks w/ my GMPP 1.6 rr's. I know they have that wierd alleng wrench thing in the center of the nut. So do I go around and get all my rockers tightened down correctly then go back and tighten the poly lock allen bolt down tight? How tight do I make it?
Old Aug 27, 2005 | 04:08 PM
Re: Tightening polylocks
Snug to firmly tighten them after adjusting lash. Nothing excessive.
Jazsun's Avatar
How much more do I turn the nut once I start to feel resistance on the pushrod?
Old Aug 27, 2005 | 04:13 PM
Adjustment
Old Aug 27, 2005 | 04:15 PM
Jazsun's Avatar
I was actually on that exact page, and printed it out before you posted. But I dont understand what it means...I have GMMP 1.6 RR's so I dont know if they follow the same as the comp cams do.
Does 1/4 turn perload sound good for medium-quite operation?
I dont understand any of this..sorry
Comp actually recommends .002-.004 preload on a warm engine.
For reference:
3/8" stud: ½ flat = .003472"
7/16" stud: ½ flat = .00416"
Rotating the nut 1/6 of a turn (until the next flat side is in the same position as the previous flat side) is a "flat".
Ohh and shoebox if you have time..checkout this thread since no one else seems to be helping:
http://web.camaross.com/forums/showthread.php?t=393063
Thanks a lot.
Old Aug 27, 2005 | 04:24 PM
Those recommendations are for Comp R lifters if you read all the text. There are also recommendations in there for stock lifters.
Victor Lamb
Aug 26, 2017 02:52 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
JCSWS6
Jul 19, 2015 06:47 PM
IowaSS
Apr 19, 2015 08:42 PM
sseeya
Apr 9, 2015 06:38 AM
