Header questions..need ground clearance ,good plug access..
Old Aug 28, 2005 | 01:08 PM
80TA's Avatar
I was going with jet hot macs but still hearing some not so good reiviews on mac fitment and quality control,welding etc.
I have my car dropped an inch with hotchkis springs so need some ground clearance.I don't want to run cats. I do want a nice coating or stainless .
I don't care that much about price. Plug access is pretty important to me along with ground clearace. Ease of install is nice too. So what is the recommendations guys?
Old Aug 28, 2005 | 01:39 PM
2000GTP's Avatar
Re: Header questions..need ground clearance ,good plug access..
Well I just installed Pacesetter Ceramic Coated LTs with the accompanying y-pipe. Ground clearance is exceptionally good, they tuck up very well, and the quality is also pretty good aside from beads of weld all over the place. Spark plug access is great on every cylinder except #2, but it is still an improvement over the stock manifolds.
Old Aug 28, 2005 | 02:56 PM
80TA's Avatar
I realize they are very pricey but think leaning to kooks non stepped longtubes.They seem to give good plug access and not hurt ground clearance.I assume they would give decent power gains with planned mods of cc 305 and le2 heads. Have zex wet kit ready for install also.
Old Aug 28, 2005 | 03:03 PM
'94 Bad A Z28's Avatar
Your car is ONLY dropped an inch.... PaceSetter LT's, my car is "slammed" as a lot of people like to say.
http://img.photobucket.com/albums/v1...o/DSC02024.jpg
http://img.photobucket.com/albums/v1...o/DSC02023.jpg
http://img.photobucket.com/albums/v1...o/DSC02022.jpg
to show how low the car is:
http://img.photobucket.com/albums/v1...o/DSC01244.jpg
http://img.photobucket.com/albums/v1...o/DSC01247.jpg
http://img.photobucket.com/albums/v1...o/DSC01246.jpg
http://img.photobucket.com/albums/v1...o/DSC01250.jpg
Old Aug 28, 2005 | 03:09 PM
FutureZMan's Avatar
Pace setters are some nice tubes, and clearance as you can see Shouldnt be an issue.
Plug clearance should be slightly improved.
BTW: nice car man, well done
Old Aug 28, 2005 | 03:14 PM
Thanks.
Old Aug 28, 2005 | 03:23 PM
80TA's Avatar
Here is pic of the vert..
Old Aug 28, 2005 | 03:24 PM
Not very low at all, get your self some LT's.
Old Aug 28, 2005 | 04:16 PM
FutureZMan's Avatar
More then enough room for some healthy LT's
Old Aug 28, 2005 | 04:48 PM
CustomSSI's Avatar
Definately look into LT's. I think we sell LT's to shorties/mids about 30 to 1. If you going to do it do it right. And 99% of LT's nowadays you don't loose much clerence.
Josh
Old Aug 28, 2005 | 10:53 PM
Z28barnett's Avatar
SLP 1 3/4 stainless coated mid lenghts on clearance at SLP.
650 or so.
Old Aug 28, 2005 | 11:34 PM
My coated PaceSetter LT's and y-pipe were less than that from texasspeed or whatever that site is.
Old Aug 28, 2005 | 11:41 PM
Z-RATED94's Avatar
1st question. Why is there water on your car? And 2nd, do you not have enough room on the inside of your car for a tach? J/K
Old Aug 29, 2005 | 01:56 AM
1st there was water on the car because I just washed it and took the pics before I dryed it, and second it's not inside because it is not a tach it is a MECHANICAL fuel pressure gauge (which means that there is fuel running all the way up to the gauge). I don't know about you but I don't want fuel pointing at my face inside my car.
Old Aug 29, 2005 | 10:49 AM
pillagenburn's Avatar
i have 93/94 style 1.3/4" headers right now ... plug access is dogsh*t though.... cylinders #5 and 6 are VERY difficult to get to.... hopefully with a thicker header gasket (copper) this will change... also re-doing the bolts with allen fitting bolts instead of these gay Stage 8 "locking" bolts
