Symptoms of a bad MAF
Old Aug 30, 2005 | 12:45 AM
CamaroSS30thAnn's Avatar
did some searching ,but nothing really helped
what would some sypmtoms of a bad maf be
i got a maf code teh other day but deleted it thinking it was maybe a glitch
i have a code for my rear 02s cuz i need sims so i really dont know if it came back untill i get it checked
anyway baf MAF symtopms??? lol
Old Aug 30, 2005 | 09:11 AM
teke184's Avatar
Re: Symptoms of a bad MAF
surging, bad idle, hardly drivable.
least that is what happened when mine went.
if it is acting funny, unplug the maf sensor. should put it into "limp home mode"
if it smooths out with the sensor unplugged it probably is bad.
least that worked for me.
Old Aug 30, 2005 | 11:11 AM
wrd1972's Avatar
Tap on the MAF with a screwdriver, if the engine RPM changes or sputters replace it.
Old Aug 30, 2005 | 12:16 PM
darkangel95's Avatar
When you unplugged your MAFS did you do it while your car was running or when it was shut off? If I unplug mine before I start my car it will not crank at all.
Old Aug 30, 2005 | 01:25 PM
teke184's Avatar
i think i unplugged it and was able to start it...
can't imagine why it wouldn't
Old Aug 30, 2005 | 02:13 PM
heres my problem , i did get a maf code the other day , i deleted it b/c i had to fix another problem , nto sure if it came back yet b/c i have rear 02 codes
my car feels like it hit a wall upon very hard acceleration, but at partial throttle or just cruisiing around its fine
my car wouldnt start the other day , id turn teh key teh ar would start and instantly die, it did it twice my buddy went under the hood and he said he wiggled the maf and teh car started right up , that coulda been a stroke of luck
any insite??
Old Aug 30, 2005 | 04:04 PM
Z95m6's Avatar
Just unplug the maf and start the car. If your problems go away then you know its the Maf. It will run with it unplugged the car will just go into speed density mode, which is the way the 93 cars worked.
Old Aug 30, 2005 | 04:18 PM
GusarskiSS's Avatar
I think the same thing is happening to my car. I have a 97' Camaro SS. I took the car to the dealer a few days ago and they put in a new AIR Injection pump. After that when I got it back, the car doesnt idle as loud anymore and it's just not as fast anymore, you can notice it.
Old Aug 30, 2005 | 09:41 PM
ok i got two codes one is
p0100 MAF circuit malfuntion , possible wireing problem
p0400 EGR flow
thin either of these can cause my problem? my car didnt do it today and teh car runs completely normal , the only problem i had today was it took 3 cranks to start my car
any insite on to whether one of these could be a reason for my problem and what to look for into fixing this?
Old Sep 28, 2005 | 04:52 PM
just checked teh wiring, power wire (pink) gets 13.85 volts and teh yellow one gets 5vs
seems right u think?
its possible the MAF is bad ?
Old Sep 28, 2005 | 11:59 PM
Honda Hunter's Avatar
I think I'm going through the same thing. The car is very hard to start without holding the gas. Once it's started it sounds like something is very wrong. Once you unplug the maf it runs like a champ and sounds better. Someone said you go into limp mode when the maf is unplugged, someone else said speed density mode. Which is it?
Old Sep 29, 2005 | 12:10 PM
speed density
timmy39120
May 8, 2015 11:41 AM
SpeedJunkee
May 3, 2015 08:49 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
