Earls Header Gaskets
Old Aug 27, 2005 | 02:17 PM
Temple's Avatar
Question Earls Header Gaskets
I did alot of searching and found that people are having success with Earls Header Gaskets. I have already blown a set of Fel-pro and want to try this other gasket. Can someone give me the part # for the Earl's gaskets I will be needing with Pacesetter LT's? Summit lists two different part #'s that will fit my application. Thanks, Kevin
Old Aug 27, 2005 | 04:24 PM
hvyss's Avatar
Re: Earls Header Gaskets
The part # is EAR-29DA3BERL. This is for the gasket kit. Both sets of inserts and aluminum retainers. They come assembled and ready to put on. They also have just the inserts but don't list the number. Good luck.
HVY SS
Old Aug 27, 2005 | 05:40 PM
Temple's Avatar
Thanks for the reply...I hope this will do the trick along with the breslin header bolts...No more leaks!!!
Old Aug 28, 2005 | 09:53 AM
Bud M's Avatar
I've been using those gaskets with Stage 8s, never any problems.
Old Aug 28, 2005 | 12:43 PM
LameRandomName's Avatar
Just want to mention...
ANY gasket will work if you follow a simple procedure:
Basically, every time you start the car, snug up all the header bolts before starting; until you find no loose bolts two times in a row.
Then double check it a few days later just to be sure.
You should only have to go through this 3 or 4 times, max; before you stop finding loose bolts.
Midnight_Z
Feb 16, 2016 09:36 PM
dylan1303
May 22, 2015 12:24 PM
4586
Apr 29, 2015 01:43 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
