How to get my Y-pipe off......
Old Aug 27, 2005 | 05:44 PM
GreenZLT1's Avatar
Red face How to get my Y-pipe off......
I have a pacesetter slip fit y-pipe and clamped it all together. I need to take it apart, but the tubing has actually been crimped, so its all stuck together. How can I get this off, and be able to put it back on? Anybody know of any tricks?
Rob
Old Aug 27, 2005 | 09:22 PM
Birdman7389's Avatar
Re: How to get my Y-pipe off......
You are gonna have to beat, wiggle and pound for a while, you could also heat the pipe up with a small propane torch or something similar
Old Aug 28, 2005 | 08:48 AM
matt65's Avatar
Heat will help, like mentioned above. I ended up having my Y-Pipe welded in, never could get the clamps to seal.
Old Aug 28, 2005 | 09:00 AM
96speed's Avatar
Depends where its stuck. If its slipped fitted on the collectors, take a BIG hammer (no rubber here) and beat the living hell out of it. It will come off.
If its the Ipipe connection, get the front (collectors) end off, point the ypipe down, and beat the living hell out of it the other direction.
If you really crimped it good you need to heat it up - like glowing red hot - or cut it. Good luck.
Ryan
Old Aug 28, 2005 | 08:09 PM
3gc's Avatar
3gc
Has anyone used these before? Summit exhaust pipe separator If so, how did it work?
Quickss96
Jan 29, 2016 05:56 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
Noer
Parts Wanted
May 4, 2015 04:58 PM
Ray66
Jul 22, 2002 11:55 AM
