pcv valve ...reloc??
Old Aug 27, 2005 | 09:04 PM
limige's Avatar
ok, bought an intake from a fellow board member that used a FAST. system on his car. he plugged many of the holes in the intake including that used for the pcv. so can i relate it to a valve cover or should i goto a dealership and see if i can get a new rubber boot for the intake....my worry is that the intake didn't have threads in that hole to begin with, i think he may have threaded it in order to plug it.
so i could use some help on this. i also have to relocate the map sensor for the same reason.....can i just T off the brake booster vacuum line for the map?
thanks
mike
14
Aug 11, 2015 12:03 PM
surreybrad
Aug 10, 2015 09:34 AM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
