Compatible blocks
Old Aug 27, 2005 | 03:36 PM
shartflhs's Avatar
Compatible blocks
I have a 1996 LT1 that i got a little over a month ago. Rather than tearing apart the motor and rebuild it I am thinking about building a new motor so I can still drive the car. Assuming I get a set of LT1 heads what chevy blocks are compatible? Is there something different about the blocks versus older small blocks? My experience is limited to older chevies, mainly big blocks so i am starting fresh here. Also i would like to have 4 bolt mains versus 2 bolt.
Thanks for any replies,
Steve
Old Aug 27, 2005 | 07:32 PM
MachinistOne's Avatar
Re: Compatible blocks
LTx blocks are gen II small block chevys. You can see the differences on the front of the block...timing cover is much different because under it is housed a third gear for the water pump...water pump boss has 2 openings per side to allow for the reverse flow cooling.
LTx heads in stock form can only work with LTx blocks
Gen I SBC heads in stock form can not work on LTx blocks
Anything can be modified to fit though...
'96 corvette blocks are 4-bolt main
I have heard that factory repacement blocks are also 4-bolt.
Old Aug 27, 2005 | 07:47 PM
shartflhs's Avatar
Thanks, that answers all my questions. I guess its going to be an LT block then.
GREEN3112
Feb 10, 2019 09:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
heus
Sep 8, 2015 12:01 PM
