egr block off
Old Sep 2, 2005 | 07:16 PM
snakethis69's Avatar
egr block off
i am having trouble with my homemade egr block offs leaking. can i just use the old sensor and plug the hole with RTV/ a boot? i got some rtv in the egr suction will this hurt my intake / engine at all?
Old Sep 2, 2005 | 10:38 PM
Re: egr block off
What "sensor"? There's no sensor in the EGR system. Do you mean the EGR valve itself?
Old Sep 2, 2005 | 10:42 PM
Re: egr block off
yup
Old Sep 2, 2005 | 10:57 PM
Z95m6's Avatar
Re: egr block off
What i did was i took my old EGR valve and cut the top of it off and ground the little metal plunger off too. I basically stripped it down to just the cast metal mounting block. I then took a piece of house flashing and traced out the pattern and cut it out. Then i used some RTV around the flashing and slipped it on, then put the EGR mounting block on to hold the flashing then tightened it down. It hasn't leaked on me yet.
Old Sep 2, 2005 | 11:00 PM
Re: egr block off
holy **** you just confused the **** outta me
but i will try that
Old Sep 2, 2005 | 11:37 PM
Re: egr block off
Did you use a gasket when you installed your plate? Is the plate thick enough to avoid deforming when you tighten down the nuts?
I have the aluminum plate from SJM Manufacturing, a stock gasket and some RTV and there is no leakage.
Old Sep 3, 2005 | 12:01 AM
Z95m6's Avatar
Re: egr block off
but i will try that
Here is a pic of an EGR valve i found. Its similar to the one on our cars but not exactly the same.
http://www.mustangmods.com/data/1787/egr_valve.jpg
I took my old EGR valve off and i broke/cut the top of it off, the part with the green arrow pointing to it. I then took the cast base part(it has the red arrow pointing to it) then traced the shape of it out on a piece of thin sheet metal. You basically make a gasket out of metal but don't put the center hole in it. Then i used some RTV on the sheetmetal and put it on the intake and then i used the cast base part to help sandwich it in place. It has worked fine for me.
Old Sep 3, 2005 | 08:50 AM
Re: egr block off
o i get it great idea, i will try that. i hve some copper lying around think that will work?
Old Sep 3, 2005 | 10:54 AM
Z95m6's Avatar
Re: egr block off
It should. You just need something to block off the port.
Old Sep 3, 2005 | 10:58 AM
69vette's Avatar
Re: egr block off
I'll send you a plate or set of plates if you need them. PM me
Old Sep 3, 2005 | 11:08 AM
Re: egr block off
what about getting RTV into the intake? wil it be very very bad? is it worth pulling the intake again to clean out?
RUENUF
Mar 13, 2016 03:37 PM
marlar98
Oct 21, 2015 02:02 PM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
