Air Foil or something else?
Old Aug 27, 2005 | 04:00 PM
Unertl42's Avatar
I just installed an air foil on my 96 z28, but about a day later, the service engine soon light came on, and it idles a lot more rough. The service engine soon light is because the fuel is too lean, so I'm going to try and take the air foil off to see if that fixes the problem. So do I need a better fuel pump or what? Thanks
Old Aug 27, 2005 | 05:16 PM
95patriotZ's Avatar
Re: Air Foil or something else?
i couldn't imagine a airfoil causing a SES light and a rough idle. I would scan it and see if it is pulling any codes. It would be easier to go from there with more info.
Old Aug 27, 2005 | 05:32 PM
zhevy-1's Avatar
Check your connections on your MAF sensor, and clean its connector, make sure the IAT is properly inserted, and your Elbow is in place right. The Air Foil should not cause your car to have those issues you're having.
-Goose
Old Aug 27, 2005 | 05:42 PM
Jazsun's Avatar
Actually if you buy the ****ty *** air foils w/ out the holes in the center for the air sensors I could see it throwing a code for some reason.
Old Aug 27, 2005 | 06:32 PM
Camarocracy's Avatar
Take a small round file and file the hole on the bottom larger.
Old Aug 27, 2005 | 08:21 PM
Silver's Avatar
perhaps your elbow wasn't put back on good and air is entering the intake after the maf.
Old Aug 27, 2005 | 10:06 PM
Janny's Avatar
Make sure that there is a hole for the engine to breathe through when the throttle plates are closed.
Old Aug 28, 2005 | 01:03 AM
Warlock1313's Avatar
I found on mine the previous owner took the elbow off and upon reinstall actuall made the bottom fold into the t/body but still went on.
Old Aug 28, 2005 | 02:09 AM
PGM95Z's Avatar
Zhevy-1
…and your Elbow is in place right. The Air Foil should not cause your car to have those issues you're having.
Warlock1313
I agree; you'd be surprised how easy it is to "fold under" the throttle body w/your elbow..
And any air entering after the MAF = bad news
94z28jbw
Sep 8, 2002 03:22 PM
ReznorZ28
Aug 27, 2002 03:53 PM
BM93Z
Aug 22, 2002 02:45 PM
turbo_Z
Aug 19, 2002 10:50 PM
NHSZ28
Jul 25, 2002 07:58 PM
