cant stop losing coolant
Old Aug 31, 2005 | 11:28 AM
1994TransAm's Avatar
its not in my oil, nothing on the floor, dont see smoke....
where do i start... i used that radiator tester, it held pressure fine... i'm worried about this guys....
i'm using head studs, new gaskets.. 300 miles so far
Old Aug 31, 2005 | 04:08 PM
94_PatriotRed_Z's Avatar
Re: cant stop losing coolant
check the fitting at the bottom of the radiator, it went bad on my car in March and I couldnt find the problem anywhere, and cook the motor on my drive home(didnt know I was low on fluid damn light was burnt out), still had the problem after the new motor, fix that fitting and I have had no problems since.
Old Aug 31, 2005 | 04:10 PM
Loadre's Avatar
Have someone else start the car while you stand behind it and look at the tailpipes. If there is a white burst you know where it is.
Old Aug 31, 2005 | 04:36 PM
blaze309's Avatar
I thought I had a blown head gasket but I wasent sure but it finally started smoking. I did however pull the some of the plugs before I knew one my head gaskets was shot. Mine were a darker tan color so i'd look at that. Although a tan color can also mean your car is running fine. I'd look at all the other little things first. I wouldn't worry about anything serious right now.
How much are you losing and how fast?
blac94Z
Feb 15, 2021 09:43 PM
FredM
Jun 5, 2015 05:45 AM
Biggiebound
Apr 21, 2015 11:28 PM
blkWidow
Apr 21, 2015 01:56 PM
MattFick
Feb 15, 2015 10:16 PM
