Guzzling anti-freeze
Old Aug 27, 2006 | 01:17 PM
94gCamaroz28's Avatar
94' LT1....no major problems. I run it through traffic in a Fresno, CA 115 degree heat wave and 5 minutes after she's parked, boiling anti-freeze spills out on the driveway. okay, the original owner i bought it from filled the thing with water (idiot), and now i've put almost a full jug of 50/50 anti-freeze. I start the car, warm it up, and take it for a spin around the block. seems fine, then overflows again. I repeat the process; fill her up, warm up, no driving around the block. I check the level and i can't even see anything, i had to use the rest of the anti-freeze just to fill up. what's the catch to this??
Old Aug 27, 2006 | 01:21 PM
95LT1conv's Avatar
Re: Guzzling anti-freeze
check you r oil, if it looks like a chocolate milkshake, then it is time to pull the heads
Old Aug 27, 2006 | 01:31 PM
NovaTodd's Avatar
Make sure you have a good thermostat and radiator cap in the car. Then fill and bleed the cooling system with the bleeder screws. AND check to make sure you don't have a milkshake in the oil.
I also run waterwetter in the antifreeze to help keep it cool. I also had MadZ28 provide a custom tune and turn the fans on at 175 instead of the factory 220+
Have you back flushed the radiator? If it is plugged up, it won't cool the car.
Old Aug 27, 2006 | 03:06 PM
dramamine's Avatar
I had a similar issue on my '96 and a new radiator cap cleared it right up. Also, make sure you get all the air out of the system.
Old Aug 27, 2006 | 05:43 PM
97TransAm's Avatar
Besides what has already mentioned, you will be surprised how many checks it will take to get the coolant system stable after an upsetting.
I had the whole system drained, water pump replaced, new thermostat install, new hoses and it took almost a week of driving cycles and "topping off" before the coolant system finally stayed full.
Hint: run the heater a few times to get the flow through there and air bubbles pushed out.
Old Aug 27, 2006 | 06:04 PM
OBE1 95Z28's Avatar
So if the original owner filled it with water and you've only added a gallon of 50/50, your at best 25% coolant.
Bleeding all the air out of your system is key.
Old Aug 27, 2006 | 06:21 PM
Blue96z28's Avatar
I think you want to run only water for best cooling performance right? Just water-wetter/straight water, and distilled if possible, if I remember correctly. Although the anti-freeze does have some anti-corrosion properties and such as well......
Old Aug 28, 2006 | 12:08 AM
I think that gives me something to work with ....now that I'm back into school 2 days a week starting tues. I will have zero time to screw around with the car...crap. I'll just have to take a day off work to settle down with this issue. Most of it can be pulled off in a quick minute or two, but knowing me, i'll want to get the majority of troubleshooting out of the way in one shot.
Thanks a lot for the input. Makes things really easy.
flames2ashes9762
Mar 13, 2007 08:36 AM
defbear
Jan 24, 2006 09:42 PM
williebeamen
Aug 6, 2005 11:17 PM
blacknwhite95Z
Mar 11, 2005 09:10 AM
