Bad Icm???
Old Aug 25, 2006 | 08:37 AM
LUDA0840's Avatar
Exclamation Bad Icm???
My car starts popping and struggling once the car gets running warm. When its cold the car runs awesome. I checked my icm and its really hot like its overheating. I've heard of a mod that might cool it down, if i seperate it with some washers. Could a overheating icm cause the car to start popping and struggling?
Old Aug 25, 2006 | 08:51 AM
Blownbird355's Avatar
Re: Bad Icm???
Here is a link to the mod you are refering to.
Old Aug 25, 2006 | 09:09 AM
camzaro28's Avatar
Re: Bad Icm???
is this under WOT or just normal driving?
Old Aug 25, 2006 | 10:49 AM
LUDA0840's Avatar
Re: Bad Icm???
normal driving, as soon as i get in the highway it clears up
Old Aug 25, 2006 | 04:03 PM
LUDA0840's Avatar
Re: Bad Icm???
ttt
Old Aug 25, 2006 | 04:27 PM
transAMdriv3r's Avatar
Re: Bad Icm???
i have the same problem and i put a new opti, wires, icm, tps, k/s ,waterpump and o2 sensors and nothing changed
Old Aug 25, 2006 | 09:40 PM
ShowStopper540's Avatar
Re: Bad Icm???
But you didnt replace your plugs, coil, MAF, or MAP sensors did you? those are also ALLLLL very important to your ignition system. As for the waterpump, i have no idea why you would try to replace that to fix a 'misfire' *shrugs*. I would first start by replacing my ICM & Coil, if nothing else, it will be good to know my components are new. Then if the problem persists, i would try to pull codes for some sensors. If no codes show up, the opti is probably going bad, mine didnt put out any codes when it went. Good luck with this, hope you fix it soon!
Old Aug 25, 2006 | 09:49 PM
playa7970's Avatar
Re: Bad Icm???
hey luda can you explain exactly what happens when the car warms up and does it happen no matter what rpm your at or only between say like 1000 to 2000 rpm?
Old Aug 26, 2006 | 09:24 AM
Re: Bad Icm???
it was leaking bad out of every corner of it on to the opti which is why it went bad. ill have to replace all the other parts you mentioned too i guess.
Old Aug 26, 2006 | 10:08 AM
LUDA0840's Avatar
Re: Bad Icm???
at any rpm, sometimes it will go smooth, its weird.
Old Dec 13, 2006 | 10:11 PM
LUDA0840's Avatar
i changed plugs. Mine were to to cold.. everything went away..
Old Dec 13, 2006 | 11:38 PM
gitsum's Avatar
What plugs did you get?
Old Dec 14, 2006 | 06:35 PM
JP95ZM6's Avatar
When my ICM failed the car would not spark at all, period. Not like your symptoms.
Old Dec 14, 2006 | 09:02 PM
slow_94z's Avatar
Mine misses only under WOT what could that be?
Old Dec 15, 2006 | 01:30 AM
1FstFormulaV8's Avatar
I'm on my 4th ICM. What usually happens. Vehicle starts, runs fine. After it heats up the vehicle just stops without warning. Starts back again after the ICM has cooled. One definitve sign that it's going. When the vehicle stops. There are no dash lights, (ie, AIR BAG, ABS, INOP, SERVICE ENGINE SOON, CHECK GAUGES;,) Pretty much the lights you get when the vehicle starts. They do not illuminate with the ICM just cuts out.
I don't know why it doesn't trigger an ECM response. Oh well, hope that little bit of info helps you in your diagnosis.
Critter
Jul 7, 2015 08:33 PM
94Z28LS1toLT1
Jun 30, 2015 12:22 PM
ad356
Apr 11, 2015 11:12 PM
maybe2fast
Mar 16, 2015 09:45 AM
USAirman93
Nov 24, 2014 03:37 PM
