Lt1 injectors fire in pairs or sequential?
Old Aug 30, 2006 | 12:14 PM
user 647483's Avatar
I noticed yesterday that the injector pigtail previously on injector #3, was
now on injector #1 (likely done when the heads/cam were installed). The only
reason I knew that was that I had blue electrical tape on in that pigtail.
The car doesn't seem to run any different when I change it, but I was
curious to know if they do in fact fire in pairs. (I'd assume the plugs fire
the same way)
Also, are those things suposed to be labeled somehow?
I didn't see anything identifying one VS the other.
- James
Old Aug 30, 2006 | 12:16 PM
TraceZ's Avatar
Re: Lt1 injectors fire in pairs or sequential?
In 93, they were batch fire. one bank at a time. right or left.
in 94 they went to sequential.
Old Aug 30, 2006 | 12:33 PM
Thanks, I'll make sure the connections are good and leave them alone then
Mixed up injector leads, not bad.
Mixed up spark plug wires, bad.
Noenav
Mar 1, 2019 07:38 AM
HectorM52
Jul 30, 2017 11:46 AM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
