need help with leak
Old Aug 27, 2006 | 08:49 PM
lt4_transam's Avatar
need help with leak
i have a 1996 trans am lt4 all was fine with it when i pulled it out to stroke it
now that i put it back together i cant get the heads to seal im using ARP head studs does anyone know if a certain part number has to be used or will the ones for a regular sbc work or has anyone ran into this before
Old Aug 28, 2006 | 12:49 AM
Ricardo's Avatar
Re: need help with leak
Is it leaking coolant or oil, and from where?
Or is the head not seating properly on the deck?
RG
Old Aug 28, 2006 | 01:15 AM
30thTA0525's Avatar
you put the heads on? where the installed correctly? with the right gasket? heads torqued properly in sequence?
Old Aug 28, 2006 | 02:10 PM
it is leaking coolant into the lifter valley it is like the heads arent seating right onto the block i used felpro gaskets for the lt1 i also used new arp head studs was wondering if they had to be retorqued after running the engine.
Old Aug 28, 2006 | 02:15 PM
)2overt SS's Avatar
Are the head gaskets facing the right way? Some gaskets fit two ways but only one way is correct. Not sure about the Fel-Pro one for the LT1.
Jeff1904
Jun 5, 2016 05:00 PM
magman
Apr 15, 2016 03:08 AM
blac94Z
Nov 4, 2015 01:59 PM
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 27, 2015 01:07 PM
