Leaks 2 quarts every 1K miles.
Old Aug 27, 2006 | 08:59 PM
carolinacasper's Avatar
I have a '93 Z28 M6 with 160K miles.
There is a bad oil leak on the back of the intake manifold. Lots of oil on the ground, not being burnt. I'm going to fix it soon.
My question is If it leaks 2 quarts of oil every 1000 miles. Do I still need to change the oil every 3000 to 5000 miles? I currently has 5000+ miles on this change and it has leaked 10 quarts of oil over the past few months.
Old Aug 27, 2006 | 09:08 PM
Compstall's Avatar
Re: Leaks 2 quarts every 1K miles.
I wouldn't worry too much about it until you get the leak fixed if you're going through that much oil.
Old Aug 27, 2006 | 09:19 PM
bombebomb's Avatar
If it leaks 2 quarts every 1k miles and you have put 10 more quarts in, thats like saying uv changed oil twice already. Of course at the point where you are, you don't do oil changes you just add more. Id recommend getting that leak fixed soon.
Old Aug 27, 2006 | 11:36 PM
Heatmaker's Avatar
Advanced Member
fix the intake leak. you'll probably spend more money on oil, than the parts it cost to fix it.
Old Aug 27, 2006 | 11:39 PM
razor02097's Avatar
you still should change the oil filter out at the 3K mark... other then that just as long as the color of the oil isn't dark your ok.
Scorch1
Jun 30, 2015 11:24 PM
Nellsw88
May 27, 2015 10:27 PM
dylan1303
May 22, 2015 12:24 PM
1loudz
Aug 20, 2002 11:45 PM
ponch333
Jul 4, 2002 02:30 PM
