Manual fan switch
Old Aug 24, 2006 | 09:24 PM
96torqueman's Avatar
Manual fan switch
Anyone know how to wire up a manual fan switch on a 96 z28? I'd like to do it through the relays???
Dave
Old Aug 24, 2006 | 09:47 PM
Kevin Blown 95 TA's Avatar
Re: Manual fan switch
The dark green wire and the dark blue wire from the two fan relays in the fuse box (under hood) need to go to ground for the fans to turn on. Doublecheck your colors, cause I have a 95. Splice into them, run the wires to 2 separate SPST switches (separate control) or one DPST switch (controls both at once) which have one pole grounded, and you have your $60 fan kit.
Old Aug 24, 2006 | 09:51 PM
SS RRR's Avatar
I have a home made 2 speed fan switch I rigged years ago. It contains 4 relays.
2 for the fans
1 for the ground wire off the fans that feeds back into the PCM (96 and up)
1 for a momentary push button. I have a switch that turns the fans on half voltage and then the push button turns the fans on w/ full. I found out that if I turned the fans on at first w/ full foltage it would blow one of the inline fuses I had in the wiring. However I also found out the switch was faulty so I'm not completely sure the switch was to blame.
I wish I still had the schematic but it was lost into oblivion soon after I got it working. If SLP is still around (I honestly don't know) they have a fan switch that's pulg and play.
Old Aug 24, 2006 | 09:59 PM
SS RRR's Avatar
Originally Posted by Kevin Blown 95 TA
The dark green wire and the dark blue wire from the two fan relays in the fuse box (under hood) need to go to ground for the fans to turn on. Splice into them, run the wires to 2 separate SPST switches (separate control) or one DPST switch (controls both at once) which have one pole grounded, and you have your $60 fan kit.
I wish I would've known that before using three thousand pounds of wire to rig mine up.
Old Aug 24, 2006 | 10:02 PM
Helms Manual
Old Aug 24, 2006 | 10:06 PM
SS RRR's Avatar
Helms Manual
Well.. I had a Haynes manual. Reason why it was rigged this way is I wasn't sure if it would throw a code if the fans were manually turned or if the PCM tried to turn them on because of that PCM routed ground wire.
Old Aug 24, 2006 | 11:17 PM
Dave
http://shbox.com/1/fan_sw_diagram2.jpg
Old Aug 25, 2006 | 12:47 AM
01Z's Avatar
01Z
I have used Shoebox's site but you can also look here.
http://www.xious.com/camaro/
Look under Modifications > install help
Old Aug 25, 2006 | 08:35 PM
Sporty-X's Avatar
you can have a SLP one through Summit for not so much. I have one and plug it in just a few minutes. Really simple
Old Aug 25, 2006 | 08:54 PM
Thanks...........a Million
I have control over the heat now.
Dave
Old Aug 25, 2006 | 09:40 PM
Sporty-X's Avatar
just one more : the SLP has a problem : it still work if the car is off and no light to tell you. In fact, i don't use it anymore since i got a 160F therm + madz28 tune. Now temp keep being always low
cristian1311
Nov 23, 2014 02:22 PM
slothgrant
Aug 22, 2002 03:01 PM
x7x7
Aug 15, 2002 06:49 PM
sfGi8nt
Aug 1, 2002 05:54 AM
