93 Trans Am Gargling noise?
Old Aug 30, 2006 | 04:37 PM
93T/A's Avatar
One person said it may be from just the trans trying to catch up
Another guy said it was his anti freeze getting into his exhaust or something of that sort due to the head gasket (That's my understanding of what he said).
I hear it coming from under the hood but low down it sounds almost near the ground. Any help would be appreciated. THanks.
Old Aug 30, 2006 | 05:33 PM
sko_spo's Avatar
Re: 93 Trans Am Gargling noise?
take off the rad cap and start the car, see if it bubbles over. if it does, then you have a blown head gasket.
Old Aug 30, 2006 | 07:11 PM
93T/A's Avatar
What's the Rad cap and what's it look like and where's it located? Thanks.
Old Aug 30, 2006 | 10:40 PM
z28trick's Avatar
radiator cap..its usually black and on the left side on top of your radiator
Old Aug 31, 2006 | 08:17 AM
SixSpeedShifter's Avatar
Engine cooling systems are pressurized (usually to 8 psi, I believe). The coolant will overflow from the radiator in perfectly normal running conditions when the cap is removed. That's why they say to never open the cap while the engine is hot.
blkWidow
Apr 21, 2015 01:56 PM
BigWil
Mar 29, 2015 12:24 PM
Fatdog2
Feb 12, 2015 12:24 PM
squarehead
Nov 21, 2014 08:02 PM
