Autolite 106 or 104?
Old Aug 29, 2006 | 12:47 PM
1LESSZ28's Avatar
I have a stock 97 z with 64k. I am planning a cam install but no head work.
My car is an a4 dd. the cam will be fairly mild but high lift.
Anyho my question is which autolite would be best for me? I will not be spraying, racing, boosting etc. I have heard some find the 106 to be too hot but with my fairly mild setup will I have any problems with the 106?
*I will get the platinum version
I figure since the 106 are factory heat range I should stick with them for better burn/ fuel mileage
Old Aug 29, 2006 | 01:09 PM
Joe B's Avatar
Re: Autolite 106 or 104?
either would be just fine, but I prefer the 104's even for naturally aspirated performance........106's are kinda hot in my opinion.....
Old Aug 29, 2006 | 01:19 PM
1LESSZ28's Avatar
would i get detonation/ less performance with the 106's?
Old Aug 31, 2006 | 09:24 AM
1LESSZ28's Avatar
anybody running the autolite 106 getting detonation/poor performance etc.?
Old Aug 31, 2006 | 10:44 AM
z28_theantirice's Avatar
Why not some NGK TR55's a ton of people have great success with those
Old Aug 31, 2006 | 11:58 AM
1LESSZ28's Avatar
well, I've not heard anything bad about the autolite's. I have heard of people having major issues with the ngk's other's run fine with them. I am also looking for a platinum plug and haven't heard much about the ngktr55gp. imho the autolite's look like a better plug and come in a double platinum for ~3.50 which is a great deal.
Personally I would rather not run anything japanese in my car if I can help it I know I'll get some flame for that comment.
Really looking for an answer to the previous question. I know what other alternatives are out there and I am not really interested in them.
Old Aug 31, 2006 | 08:29 PM
MachinistOne's Avatar
NGK's have a bad history of the porcelin breaking, I have not used them since as they claimed there was not an issue and ignored their customers. I only use Autolite plugs and NEVER have spark plug related problems.
Use the 106's for a stock motor.
Old Sep 8, 2006 | 02:17 PM
klrz28's Avatar
I had the 106's on my 383 at the dyno and one died on the way home... whats the best plug for a 383 N/A?
Old Sep 8, 2006 | 02:30 PM
Severous01's Avatar
sorry, dont use autolites...i run NGKs only. i've had a lot of bad luck with champion/autolites. even bosch wouldnt work for me.
Old Sep 8, 2006 | 02:32 PM
klrz28's Avatar
what gap do u use? i have ltcc my builder says go .055 or .060
Old Sep 8, 2006 | 03:52 PM
I've run the Autolite 104's (NA) and 103's (125-shot), along with some Champions (S57YC) for the 300-shot, and haven't had a problem in the 6 years the engine's been running. A also ran the NGK TR6's when the engine was a stocker with a dry nitrous kit.... again, no problems with those plugs either.
1LESSZ28:
A stock heat range plug should be fine for your setup.
Old Sep 8, 2006 | 04:21 PM
Wckd94Z's Avatar
I'm running the Autolite 106s on my car, heads, CC306 cam, 88k mile shortblock.
I'm not getting any detonation here in So Cal on 91 octane in 105* weather. Also my heads have 56 cc combustion chambers so my compression is in the 11.0 range I believe. Car runs very well, I was running Delco platinums before, I like the 1.29 autolites much better
Old Sep 8, 2006 | 08:06 PM
rob97ss's Avatar
Autolite 104's in my 383 for the past two years no problems
Old Sep 9, 2006 | 01:50 AM
93Phoenix's Avatar
Why not 605s?
Old Sep 9, 2006 | 03:15 AM
Heatmaker's Avatar
Advanced Member
I can voucher for that and so can my #8 cylinder
