Help! I need valve covers for my LE2!
Old Aug 29, 2006 | 08:00 AM
1997Z's Avatar
Exclamation Help! I need valve covers for my LE2!
We are trying to finish my LE2 install but we can not find any tall LT1 valve covers. Summit told me their custom aluminum covers would work but they are not even close. I know this is probably the simplest part of the job, but it is taking the longest. The Canton fabbed covers are back ordered. I need some ASAP.
What valve covers do you LE2 owners use?
Old Aug 29, 2006 | 09:32 AM
TQdrivenws6's Avatar
Re: Help! I need valve covers for my LE2!
I just have the stock valve covers with the lips on the fins bent straight. They work just fine, and I don't have any clearance problems.
Old Aug 29, 2006 | 10:15 AM
Javier97Z28's Avatar
Moderator
You can use your stock covers., as mentioned above, just crimp the fins.
Old Aug 29, 2006 | 11:07 AM
pntballty's Avatar
Yeah what they said. I had a link to a walkthrough but it looks like its down...
Old Aug 29, 2006 | 01:03 PM
yotaman96's Avatar
Yep, did the same thing here. Just straighten the bracket lip.
Old Aug 29, 2006 | 03:43 PM
FryedClutch's Avatar
actually summit should have some
i had the same prob when i had mine except i had standard SBC roller rockers on and they were way to tall
but anyway
they valve covers are made by proform and the ones i got were black and said chevrolet in red on them
but they were def taller than stockers
pro-141-131 black
pro-141-130 silver
Old Aug 29, 2006 | 05:36 PM
1997Z's Avatar
but anyway
pro-141-131 black
pro-141-130 silver
Did you have to mod the covers? The guys working on my engine say I can not have baffles and SBC valve covers will not clear my alternator.
Old Aug 29, 2006 | 08:44 PM
nope didnt have to modify them at all they just dropped right on
and to tell you how much more clearance i had
the stock covers would just sit atop the rockers leaving about an 1/8th inch of clearance between the valve cover and the head got those from summit and dropped em right on no issues
but i did grind on the alternator a lil bit
it was very close to fitting though
Old Aug 29, 2006 | 08:53 PM
1997Z's Avatar
Thanks for your help everyone... I am going to try to mod my stock covers for now. Then I will get the covers that FryedClutch recommended. I think I will have a nice set of Summit fabbed aluminum covers for sale relatively cheap pretty soon if they will not take them back.
I do not have my stock covers with me. How do I straighten the lips on them? I have no mechanical skills... lol.
I am dying to get my car fired up!
Old Aug 29, 2006 | 10:05 PM
blackztpi's Avatar
if you want a little help in the looks department, get some polished aluminums off of ebay that have the notch for our alternators. they fit decently well and look a lot better than stock
Old Aug 30, 2006 | 03:21 AM
yotaman96's Avatar
Look at the braces in the valve cover. You will notice they have a 90 degree angle that caused it to have a small lip. This lip hits the wide rockers. Take a wide pair of pliers and straighten the braces so that they don't have the 90 degree turn any more. You may also have to squeeze in the sides of the baffle on the passenger side valve cover. Once you do this, they should go right on.
Old Aug 30, 2006 | 09:53 AM
1997Z's Avatar
Thanks for your advice... I passed this on to the guys working on my car. I hope it works!
Old Oct 5, 2007 | 11:12 PM
RPWS6's Avatar
My thoughts:
http://web.camaross.com/forums/showthread.php?t=526632
Old Oct 5, 2007 | 11:42 PM
WS6T3RROR's Avatar
Then break out the die grinder and hack the bracing out of the intake side of those too. Not a dig on you by any means but i had to grind the living **** out of mine to make them fit over my 7/16" 1.6 pro mags. that brace is about 1/4" wide and theres next to no room between pro mag trunions.
Old Oct 6, 2007 | 07:32 AM
wrd1972's Avatar
Stockers here, I cut the braces in question out with sheet metal shears. The entire valve cover mod took maybe 45 seconds per cover.
I eventually want to get some LT4 covers to help reduce rocker noise down the road.
