New wish list for my LT1
Old Aug 30, 2006 | 12:39 AM
razor02097's Avatar
putting together a wish list for my 94 LT1 camaro. The plan is to have a stock engine with a few power adders and performance handling parts. So far the list is like this...
Z28 Parts List
INTAKE
SUM-57-3010-1 Air Intake, Tube/Black, Filter/Red, Chevy/Pontiac, Camaro/Firebird 1993-97, 3.4/5.7L, Kit $175.95
EXHAUST
HOK-16765HKR Exhaust, Y-Pipe, Aluminized Steel, Chevy/Pontiac, Camaro/Firebird, Each $182.69
HOK-16827HKR Exhaust System, Super Competition, Cat-Back, Aluminized, Chevy/Pontiac, Camaro/Firebird, Kit $279.95
HOK-2231-1HKR Headers, Super Comp., Full-Length, Ceramic Coated, Chevy/Pontiac, Camaro/Firebird, 5.7L, Pair $649.95
IGNITION
ACC-49324 Ignition System, 300+ Digital with Coil, Chevy/Pontiac, Camaro/Firebird, 5.7L, Kit $239.95
MSD-32149 Spark Plug Wires, Super Conductor, Spiral Core, 8.5mm, Red, 90 Degree Boot,Chevy Camaro 5.7L $84.88
NGK-3951 Spark Plug, V-Power, Tapered Seat, 14mm Thread, .708 in. Reach, Projected Tip, Resistor, Each $2.39
COOLING
CSI-901LT1 Water Pump, Electric, 30-37 gpm, Billet Aluminum, Clear Anodized, LT1, Chevy, Small Block, Each $159.95
HANDLING
EDL-5228 Strut Brace, Front Upper, Steel, Black Powdercoated, Chevy/Pontiac, Camaro/Firebird, Each $119.88
SLE-70802 Subframe Connectors, Weld-On, Steel, Black, Chevy/Pontiac, Camaro/Firebird, Each $257.95
STQ-51055 Sway Bar, Rear, 1 in. Diameter, Steel, Gray, Chevy/Pontiac, Camaro/Firebird, Kit $119.88
TRANS
BMM-45051 Manual Shifter, Short Throw, Ripper, Chevy/Pontiac, Camaro/Firebird, Each $164.95
BRAKES
RUS-692060 Brake Lines, Street Legal, Braided Stainless Steel, Chevy/Pontiac, Camaro/Firebird, Kit $95.88
So what do you think? Any suggestions or additions to the wish list?
Old Aug 30, 2006 | 01:26 AM
IdahoLT1's Avatar
Re: New wish list for my LT1
If its for the track I would add gears and some sticky tires. Other than that i wouldnt have the ignition box on there unless you plan on FI or h/c.
Old Aug 30, 2006 | 01:51 AM
nickp's Avatar
get nitrous.
Old Aug 30, 2006 | 09:04 AM
2000GTP's Avatar
Is all this stuff from Summit by chance? If so, I would also search through our supporting vendors, they have alot more LT1 specific parts then Summit and they run specials for us all the time. As for what you have picked out, the intake is a good idea, as is all of the exhaust components you picked out and the electric water pump. The ignition box is a waste of money as well as the stainless brake lines. I would also count out the 1" sway bar. Otherwise, the subframe connectors, strut tower brace, spark plugs, and wires are all good ideas as well. As for stuff to add, as already mentioned above, nitrous is one of the better bang for the bucks mods as is a mail-order tune from one of these guys: www.madz28.com or www.pcms4less.com
Old Aug 30, 2006 | 05:45 PM
razor02097's Avatar
no nitrous. This will be a street car.
I will check out the vendors of the web site but I was very happy with summit that is why I have the whole list from there. I know gears are a good way to improve acceleration but I doubt I will be swapping for a set any time soon. The intake and cat back will be bought soon leaving the headers and Y pipe for later as they cost much much more. Next would be the short throw shifter then probably new tires by then. I have a friend in the CAD field that is happy to design a strut brace for me so I may have that custom, and the sub frame connectors will be bought once I have my new TIG welder.
Old Sep 3, 2006 | 12:28 AM
IdahoLT1's Avatar
And dont upgrade the lt1 brakes. I switched to the LS1 brakes and it has saved my a** on many occassions. Bigger rotors + dual piston calipers = excellent stopping power over stock.
DirtyDaveW
Dec 1, 2016 05:37 PM
Brake_L8
Jan 20, 2015 09:44 AM
Dec 5, 2014 11:42 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
