MSD 8.5's OVC??
Old Aug 27, 2006 | 11:05 AM
gixxer92's Avatar
MSD 8.5's OVC??
Anyone going over the valve covers with these? Any Problems? Is there a specific part number for the cut to fit's on a LT-1?
Old Aug 27, 2006 | 11:13 AM
Bersaglieri's Avatar
Re: MSD 8.5's OVC??
Why run over when the kit they make fits so perfectly along/under the heads?
-Dustin-
Old Aug 27, 2006 | 11:21 AM
gixxer92's Avatar
Re: MSD 8.5's OVC??
How do they clear the headers? did you attach them to the block? Just asking before I invest $80 in another set of wires.
All infor on them is welcome I have worked with them yet. I take it they are cut to fit?
Old Aug 27, 2006 | 11:27 AM
Re: MSD 8.5's OVC??
I got them for 60 from Summit, and they run great. Run the passenger side either through the motor mounts or between the block and AC compressor or both. The drivers size I ran the first two cylinders under and the rear two all the way outside the headers, along the shock tower and back. Zip ties are the only other thing youll need. Hooker LT headers.
They are a pre cut kit. I tried the cut to fit crap and its not worth it when the LT1 kit runs so easily.
Just dont run the passenger side around the block where the stock wires went, they will crack due to the sharp angle and tight fit.
-Dustin-
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
