Optispark Testing
Old Aug 24, 2006 | 04:21 PM
GOTPLZ2's Avatar
Optispark Testing
If I'm getting 12 volts to the opti from the coil wire and have no spark at the sparkplugs does that mean my opti is bad for certain or could it be a bad ground? How is the opti grounded? I read one place that pin d on the electrical connector is ground but a diagram on shoebox's sitehttp://shbox.com/1/95_ign_system_schematic.jpg shows it as Distributor low reference. I read shoebox's article on this and it makes me think that if you get volts to the opti thru the coil sparkplug wire and no spark at the sparkplugs it means the opti is bad. http://shbox.com/1/4th_gen_tech2.html#opti_test
But I wanted a definate yes before I buy a new one.
Old Sep 3, 2006 | 08:59 PM
SSCamaro's Avatar
Re: Optispark Testing
If thats your comment, then the "opti" should be fine and the rotor, and or, cap took a dive.
Old Sep 3, 2006 | 11:22 PM
Do you mean you are getting spark in (via the coil wire) to the opti, but no spark out? That would be a cap/rotor problem.
Old Sep 4, 2006 | 06:20 AM
Mtrhds94Z's Avatar
The opti is grounded by the engine block it's bolted to.. not a wire..
KYWes
Jun 14, 2022 06:52 AM
Girrrrl
Aug 20, 2015 06:17 AM
Aug 17, 2015 09:50 AM
karpetcm
Aug 14, 2015 03:02 PM
asilomar244
Jul 12, 2015 05:53 AM
