Code ?'
Old Sep 3, 2006 | 10:11 AM
97CreamSickL's Avatar
Code ?'
I pulled a P0113(IAT Circuit high input)and P0118(Engine coolant temp high input)Now this is probally a rookie question but is the sensor that is maulfunctioning or is the curcuit itself.I have no problem testing the curcuit being that I work on low vltg dc curcuits for a living.Would this explain my starting issues.
Old Sep 3, 2006 | 11:47 AM
Re: Code ?'
Maybe Injuneer or Shoebox can chime in!!
Old Sep 3, 2006 | 12:04 PM
Re: Code ?'
http://shbox.com/1/4th_gen_tech2.html#ect
Old Sep 3, 2006 | 12:37 PM
Re: Code ?'
Those codes corresponds to high voltage = high resistance, generally an open circuit.
Old Sep 3, 2006 | 12:46 PM
Re: Code ?'
Thanks fellas.Could one of those sensors cause hard starting issues?
Old Sep 3, 2006 | 10:20 PM
Re: Code ?'
Yes. A faulty coolant temp sensor can make the PCM think the engine is very cold, an it loads up the fuel for a rich cold start. If the engine isn't really that cold (-40degF is the open circuit temp) it isn't going to run very well. A faulty coolant temp sensor may also prevent the PCM from entering closed loop.
The IAT sensor doesn't cause much in the way of problems on the MAF cars (94-97), only on the 93 speed-density cars.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
