Smoke at WOT ONLY
Old Sep 2, 2006 | 02:00 PM
30696bird's Avatar
Smoke at WOT ONLY
This has happened twice now, once about 3 months ago and now yesterday. On my way home from the track I have to get on I-75. Well, car's running great and every once in awhile for some reason I feel like hitting the gas on the interstate. Yesterday I was next to my ex-wifes brother who went to the track with me (he drove his car), and the other time this happened I was coming back from the track and there was a nice foxbody that wanted to race (or so he thought ). Anyways, my car NEVER smoke while I drive it normal and does not at high RPM's except these two times. What happens is when I'm @ 6200-6300ish for a long period of time (1/2 mile- mile) it lets out a BIG plume of smoke! Not like it smokes a little it looks like the engine blew up (first time I thought it did). Once the smoke clears up......about a mile of driving, I can nail the gas and there is NO smoke. What causes this? I think maybe at high rpm's the rings just can't handle the volume and it blows by. Am I on the right track? Or should I be concerned?
Old Sep 2, 2006 | 02:48 PM
CamaroRacing12's Avatar
Re: Smoke at WOT ONLY
sounds like a problem.....if its that much smoke....
Old Sep 2, 2006 | 06:31 PM
Severous01's Avatar
you likely popped a valve seal. i did when i hit that high. i just went ahead and rebuilt the whole motor...had other problems too so i did them all at the same time
Old Sep 3, 2006 | 09:50 AM
30696bird's Avatar
If I popped a valve seal wouln't it constantly smoke? It stops after driving a mile or so.
Old Sep 3, 2006 | 10:11 AM
Severous01's Avatar
mine didnt. just at higher rpm. and under hard pressure like climbing a hill or something.
Old Sep 3, 2006 | 01:20 PM
OBE1 95Z28's Avatar
My friend's cat blew it's honeycomb out, it let loose a cloud of smoke. Seeing that's yours is a dual cat car, maybe it was each cat at separate times; if you're still running cats.
Old Sep 3, 2006 | 02:32 PM
30696bird's Avatar
X-pipe no cats. I don't think it's a big deal because it only happens if I'm on it for LONG periods of time. I can go outside, jump in it and floor and and there will be NO smoke. But if I stay in it (at high speed, high RPM's) it will plume.
PopoFormula
Oct 12, 2015 04:19 PM
greenzee28
Sep 25, 2015 04:29 PM
SEOJustin
Sep 24, 2015 04:39 PM
jackpawt883
Sep 10, 2015 08:53 PM
blaze309
Sep 8, 2015 05:27 PM
