Ok..about to bring my block and parts to golen..need some suggestions.
Ok well..im doing a 355 with the STOCK (38,000 MILES)crank, scat 5.7 cap-screw I-beams(7/16th bolts) and SRP .030 -24CC blower pistons. This is going to be for a "stock" revving(having cam built to max out around 6krpms) turbo car. Im going with a PTK kit..front mount, and meth,76mm running 10psi on the street and maybe 14 on race gas at the track.Now, I want to bring my block and ALL of the parts to the builder...and get back a complete short block. Tell me what im missing:
stock crank
rods
cam
cloyes timing chain
pistons
arp (2bolt main)studs on stock caps.
Now for the suggestions
PISTON rings...WHICH rings should I go with? This will be a daily(summer) dry,driven car. I only want to run 10psi.(fuel limited) Whats a good boosted set of rings that wont chew away at the block(again..for a turbo car this is going to be "low" hp..maybe 600rwhp. I just want 10.99'slol.
Oil pump?Stock? How bout oil pick up and all that?
And what else am I missing other than bearings(hes going to supply those). I want to bring him all the parts(minus bearings) and say..built this.(ill be putting the top of the motor together) As you can see this is going to be a semi budget engine..to pretty much last me all of next summer to get able to get used to a turbo car..before I go spending 4-5 k on a block
stock crank
rods
cam
cloyes timing chain
pistons
Re: Ok..about to bring my block and parts to golen..need some suggestions.
If Golen is going to do it let him choose the parts for warranty. Ya might ask him about any upgrades he might have for your set up.
well I have everything i listed before...i was just wondering what all you guys were using for rings..and the oil pump. Also..anyone ever deal with golen? chad seems to be a great guy on the phone..
I am putting in Moroso race pump in my new motor , 22100 http://www.moroso.com/catalog/catego...?catcode=14444
F'n1996Z28SS
Aug 23, 2023 11:19 PM
