Mahle pistons and n20.
Old Aug 25, 2006 | 11:36 AM
TravisA's Avatar
How much n2o do you think the mahle's will handle?
I was thinking of building a little 355 and spraying a 200-300 shot on it. I was also looking at the ross racing pistons part# ros- 90465.
Travis
Old Aug 25, 2006 | 11:57 AM
SStrokerAce's Avatar
Re: Mahle pistons and n20.
The ringland depth and piston alloy on the Mahles is not the best for a big shot of N2O. I don't know the same things about the Ross piston though.
Bret
Old Aug 25, 2006 | 12:00 PM
GetaZforgetGT's Avatar
Make sure you plan to build up the bottom end also for a nitrous shot like that.
On mine I went with 4bolt splayed mains, forged crank and rods.
I had a custom set of Wiseco pistons made with the heavy duty wrist pins.
A 300 shot is a big shot on even a built LT1 so your tune will have to be spot on.
Old Aug 25, 2006 | 12:01 PM
Bret the Ross pistons are rated for 8.5 lbs of boost or a 250 shot per summits website.
http://store.summitracing.com/partde...5&autoview=sku
Old Aug 25, 2006 | 12:44 PM
TravisA's Avatar
A 300 shot will be way down the road if I do it. I'll more than likely be running a 200 shot but I could get wild down the road and up it to a 250 or 300 shot.
I'm in the planning stages right now but what I want is a 355 that runs high 9's on the bottle and low 11's on motor. I'll be modeling my setup after T/A LT1's...
Old Aug 25, 2006 | 12:53 PM
Ok so why the dish pistons and low compression?
I normally just get a shelf piston from Diamond and have them make a change to lower the top ringland down to the proper height for me for the N2O useage.
Bret
Old Aug 25, 2006 | 01:10 PM
TravisA's Avatar
The ross is a flat top piston with 4cc valve reliefs. If the calculator is right that I used it should be around 10.7:1 with a 1074 gasket and 58cc chamber.
With a zero deck and the same setup it should give around 11.4:1 ?
Old Aug 25, 2006 | 01:15 PM
Yes definately Zero Deck it.
Bret
Old Aug 25, 2006 | 02:18 PM
Jlo's Avatar
Jlo
Bret
Would you recomend a Zero Deck on all builds.
Old Aug 25, 2006 | 02:56 PM
yep, unless you can get the quench right another way
Old Aug 25, 2006 | 05:53 PM
Jlo's Avatar
Jlo
So with the 1074 Felpro gaskets and a flattop piston, it's better to zero deck it. Cool.
Old Aug 25, 2006 | 06:15 PM
1racerdude's Avatar
Stock LT1 heads are 54CC,LT4's are 58.
It will be hard to spray 2 seconds off of it.
Old Aug 25, 2006 | 08:55 PM
TravisA's Avatar
I was going off Clint's(T/A LT1) times....11.15@121mph N/A and 9.83@136mph with 175 shot.
Old Aug 25, 2006 | 10:25 PM
1racerdude's Avatar
Originally Posted by TravProcharged94Z
I was going of Clint's(T/A LT1) times....11.15@121mph N/A and 9.83@136mph with 175 shot.
Gonna be hard to believe just a 175 shot.
Old Sep 30, 2006 | 08:13 PM
1redTA's Avatar
LT1 are 58 the 54.4 cc are the LT4 as advertised
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
