what cars came with 3.08 rear gears stock?
Old Nov 2, 2003 | 03:52 PM
anasazi's Avatar
just downloaded my computer, it thinks it a Y-body with P285 55 17's and a 3.08 rear gear...
what years and cars did the 3.08's come out of? how can i tell what i really have back there?
Old Nov 2, 2003 | 03:58 PM
94GrayV6's Avatar
Umm...the only 4th gens that had 3.08s are the non-Y87 equipped 3800 V6 cars.
Old Nov 2, 2003 | 04:08 PM
ishz28's Avatar
As far as Corvette's go, 3.08 could be found in 1963- 1979 models. 1980-1982 models 3.07, 1984-1996 3.56 and 3.73 only, in the Dana 36. I "believe" this is correct.
Old Nov 2, 2003 | 05:16 PM
A '57 Chevy with a Powerglide transmssion came stock with 3.08's.
Old Nov 2, 2003 | 05:22 PM
Notford95's Avatar
The 8.5" 10 bolt in b-bodies (Impala SS, Caprice, Roadmaster etc.) comes with 3.08 (among other things), but unless you swapped the whole rear axle , that should not be the case. I have not heard of anything other than 2.73, 3.23, and 3.42 for V8 f-bodies.
Matt
Old Nov 2, 2003 | 06:21 PM
anasazi's Avatar
is there any way i can phyiscally look at what i have in the rear?
Old Nov 2, 2003 | 06:31 PM
zoso1959's Avatar
how to check
open your driver's door and look for the code:
GU2 EQUALS 2.73
GU3 EQUALS 3.23
GU3 EQUALS 3.42
hope this helps
Old Nov 2, 2003 | 06:50 PM
A little more accurate:
GU2 : AXLE REAR, 2.73 RATIO
GU4 : AXLE REAR, 3.08 RATIO
GU5 : AXLE REAR, 3.23 RATIO
GU6 : AXLE REAR, 3.42 RATIO
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
