LT's and stock wires...
Old Nov 1, 2003 | 10:04 AM
madwolf's Avatar
Arrow LT's and stock wires...
Will they last at least a couple of weeks or no chance at all?
I will go with the OVC setup soon, but right now I still have stock wires on the engine and I'm doing a cam and lts today...
Old Nov 1, 2003 | 11:01 AM
rpm4lalo's Avatar
I have MSD 8.5mm Superconductors and jet hot longtubes.
I am not using the OTV setup. Just got some taylor firesleeve for ceratin spots where I thought the wires might touch and used plenty of zip ties in other places to prevent them from getting to close to the headers and this has worked for over 15,000 miles now.
Old Nov 1, 2003 | 11:26 AM
$hawn's Avatar
I have the jet hot LT's and I have the wires in the stock location, I just zip tied them to those black brackets attached to the block, for wires #3, 5, 4, and 6.
Old Nov 1, 2003 | 11:40 AM
doodad's Avatar
Definitely get some firesleeves Ion. Unless you just like changing plug wires. I burned three (all on the pass side) in three weeks after the header install.
Old Nov 1, 2003 | 12:59 PM
carlos64030's Avatar
Save your money on the fire sleeves and pick up some $14.00 heat reflective tape, and wrap some around the closest contact points on your plug wires. Also, use the tape to wrap up the harness that runs down to the starter, knock sensor, and O2 sensor.
Old Nov 1, 2003 | 01:20 PM
$hawn's Avatar
Carlos, where all can you get this heat reflective tape at, my wire harness is close and I need to do something about that.
Old Nov 1, 2003 | 01:49 PM
buelldevil's Avatar
Has anybody considered wrapping the exaust instead? This should protect your wires and keep under hood temps down.
ZDriver96's Avatar
summit, jegs, thunderracing, tbyrne, and most likely autozone.
If that header touchs the heat reflective tape it'll burn right though it... It reflects heat but does not hold up against it on contact.. I used stock wires but I had an extra long wire that i had to go over the valve cover with, drivers side 3rd one back.
Old Nov 1, 2003 | 02:07 PM
rpm4lalo's Avatar
Do not use "header wrap" on a header that has Jet Hot coating or equivalent.
Old Nov 1, 2003 | 03:19 PM
atljar's Avatar
Ive been running wires in stock location for a few years now.
Drivers side they all get tucked against block, no problems.
Passenger side is a bit more tricky. # 6 and 8 get routed behind the dipstick tube (close to block), and under starter wires. 2 and 4 are just routed against the block. However, i run all the wires behind and under the accessory bracket so they come up to the opti, instead of down to it. (right above/behind tensioner) Its really tight getting the boots through, but they fit.
Old Nov 1, 2003 | 08:58 PM
revtime's Avatar
I have Jet Hot Hooker LTs and MSD superconductors run without OVC.
I don,t see any reason to run OVC unless you like the looks, I have over 4k miles on the LT install with no burnt wires.
Routing is the key.
Old Nov 1, 2003 | 11:30 PM
Schantin's Avatar
Routing is the key.
I fully agree. Whenyou install the LT's, common sense and a thorough visual inspection will tell which wires are in danger of getting burned. Most are on the passanger side. I carefully tied all the potential "burn victim" wires to corresponding looms or other wires with long black zip-ties. After 3K miles....no burnt wires.
It did take a couple looks and about two hours between "strategizing" and actually tying off the wires to get the job done. Long story short...take your time and ou'll have no troubles with LT's and stock wire routings. There is no need for reflective tape or fire sleeves.
Schantin
1997 Camaro Z28
Virginia Tech 31 - Miami 7
Old Nov 2, 2003 | 12:10 AM
I'm with you revtime...I don't like the OVC look... to messy looking.
Old Nov 2, 2003 | 02:55 AM
96LT14u2Nv's Avatar
you will be fine if they are routed good. i have also been running wires in the stock location for as long as i have had LT's. just use something on the boots to deflect the heat.
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
