rear end cover
Old Nov 2, 2003 | 08:04 PM
1FASASZ's Avatar
rear end cover
just got my new gears and i was wondering if its worth it to buy a new heavy duty rear end cover? what do they do that stockers dont?
Old Nov 2, 2003 | 08:30 PM
KCFormula's Avatar
If you buy one with girdle studs in it, they preload the berrings in the rear end which help with rigidity. They are a good thing to have if you plan on keeping street tires on it. But with sticky tires you can't get around needing a 12bolt.
Old Nov 3, 2003 | 01:16 AM
revtime's Avatar
TA cover is a good investment in my opinion.
True if your gonna run a slick or ET streets then you might want to invest in a stronger rear but if all your gonna run is a BFG or Nitto then you should be all right.
Automatic cars will not eat rear ends like a 6 speed will.
Old Nov 3, 2003 | 09:30 PM
96LT14u2Nv's Avatar
they are a waste IMO. cheapest thing u can do to make your rearend stronger is to weld the axle tubes. that is all i have done to mine and it is holding up fine on ET steets
Old Nov 3, 2003 | 10:02 PM
1FASASZ's Avatar
how do you do that? do you have pics?
Old Nov 3, 2003 | 11:06 PM
flyinZ's Avatar
I've heard about welding the tubes', but didn't know where/how?? Can anybody explain?
Old Nov 3, 2003 | 11:07 PM
lethal93ta's Avatar
im welding mine, getting a cover and moser gears this winter ill see if they will hold up.
Old Nov 5, 2003 | 08:41 PM
1FASASZ's Avatar
what exactly do you weld?
Old Nov 5, 2003 | 08:47 PM
lethal93ta's Avatar
the axle tubes to the pumpkin, from factory there just press fit in and can move
Old Nov 6, 2003 | 08:54 AM
RacinZ's Avatar
Just remember when you weld the tubes to do it in sections as not to warp the tubes. On my Dana we did 1" at a time then the opposite side and kept going around till we had a full bead.
Old Nov 6, 2003 | 06:54 PM
1FASASZ's Avatar
what part of the tube do you weld
Old Nov 6, 2003 | 07:09 PM
RacinZ's Avatar
The tube axle tube that goes into the housing. Right now it's only pressed fit. welding will make it a little stronger and help prevent from flexing.
Old Nov 6, 2003 | 07:48 PM
1FASASZ's Avatar
does anyone have pics of were to weld
CARiD
Feb 9, 2015 09:35 AM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
