Trans wont go into gear when cranked, but will when turned off... wtf?!
Old Nov 2, 2003 | 11:03 AM
pillagenburn's Avatar
just like the topic says ... trans wont go into gear when turned on but will when turned off ... no idea whats going on. Just replaced the clutch hydraulics so im not sure why its not going into gear.
thanks!
Old Nov 2, 2003 | 11:11 AM
buelldevil's Avatar
Sounds like you need to bleed some air off of the slave cylinder.
Old Nov 2, 2003 | 11:25 AM
carlos64030's Avatar
Did you replace the slave cylinder and master cylinder as a unit, or the slave cylinder only?
Old Nov 2, 2003 | 11:55 AM
i replaced everything ... master cyl, slave cyl, and reservoir. The whole unit came pre-bled from GM, so i dont think air in the line is a problem.
any other ideas? throwout bearing maybe? its a SPEC Stage 3 Ceramic clutch, and is not even 5,000 miles old.
thanks
Old Jan 7, 2004 | 01:03 PM
allamerican29's Avatar
did you fix your problem and if you did what was it. i just happened to me a couple hours ago. haven't had the chance to tear it apart yet.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Noenav
Dec 6, 2014 07:35 PM
