02 simms needed on long tube install???
Old Nov 2, 2003 | 03:35 PM
MarkyMark's Avatar
Go
Are 02 simulators needed on a long tube install? I am going with non emissions Jet Hots and an off road Y pipe. I plan on getting mail order tuning...so do you still need em or will the tuning eliminate the need for 02 simms?
Also should i get Oxygen sensor extensions for the first two oxygen sensors?
________
Web Shows
Old Nov 2, 2003 | 03:38 PM
Seal's Avatar
u'll need 2 oxygen sensor extensions for your front o2s (you cant put a sim on the front ones) for the back ones they can get disabled with the mail in order... so u wont need it but u do need o2 extensions, and i highly recommend a pair for front o2s from acdelco, just change them while down there...
Old Nov 2, 2003 | 04:03 PM
MarkyMark's Avatar
Go
ok thanks........what size extensions should i go with? the longer ones or the shorter? And where is a good place to pick up the AC Delco brand Oxygen sensors?
________
Live sex webshows
Jan 5, 2015 07:14 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Jul 4, 2005 05:00 PM
NED4SPD
Sep 16, 2002 10:45 PM
