No Spark!?!?!
Old Oct 30, 2003 | 08:46 PM
Blu85ROC's Avatar
Angry No Spark!?!?!
What's the deal... I just changed the distributor, cap and rotor, ign. coil and module on my formula and I'm not getting any spark from the coil. Strange thing is, it ran like a champ for about a week then without warning it wouldn't start... i'm confused to say the least, any insight into the problem would be greatly appreciated.
Old Oct 31, 2003 | 10:44 PM
Blu85ROC's Avatar
Angry
Any ideas, and what's with the black dot on the letter symbol?
Old Oct 31, 2003 | 10:51 PM
DarkRider's Avatar
first of all you'd probably be better posting this in the 3rd gen forum
What does the car do when you crank it (used to have 85 ta)
Old Oct 31, 2003 | 10:56 PM
Seal's Avatar
it says 97 formula
Old Oct 31, 2003 | 11:02 PM
jasons93z's Avatar
This may sound stupid, but when you hooked up the new opti, did you make sure u plugged in the harness. Also, check the fuses.
Old Oct 31, 2003 | 11:12 PM
DarkRider's Avatar
Originally posted by Seal
it says 97 formula
Sorry - when it gets late I don't read everything
Old Nov 1, 2003 | 07:23 AM
If you replaced cap and rotor only, that could be your problem. Have you scanned for any codes? What was the reason you replaced the cap and rotor in the first place?
You can try some things with this test.
The black dot is for threads that you posted to.
Old Nov 1, 2003 | 01:39 PM
Blu85ROC's Avatar
Thanx for the help... I replaced the opti with the cap and rotor. The water pump had leaked onto the first one... destroyed... replaced the cap and rotor 'cuase they were the original (101k), and I cheked the connectios first hoping that would be it. I still got no clue.
thanx agian,
Daniel
PS Shoebox... thanx for the link, great stuff!!!
Old Nov 2, 2003 | 07:42 PM
Blu85ROC's Avatar
ttt
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 02:44 PM
SEOJustin
Sep 24, 2015 04:39 PM
