cant loosen coil nuts
Old Oct 31, 2003 | 08:42 PM
b-stevens's Avatar
The right side lugs, 2 nuts with a ground inbetween.. are stuck together and cant get them loose... What should i do????
Im trying to replace my coil so help! thanks in advance
Bob
Old Oct 31, 2003 | 09:32 PM
ead94z28's Avatar
Spray em with a little PB Blaster, and let it sit for an hour or so. Do not force them or you'll break the studs.
Old Oct 31, 2003 | 09:33 PM
b-stevens's Avatar
PB Blaster? where can i get it and what is it?
Old Oct 31, 2003 | 09:40 PM
ead94z28's Avatar
Most auto parts stores. It is a compound that breaks apart the rusted, hard to get off, bolts. It comes in a spray bottle. It works great. Depending on how bad the studs are, it might take a while to work.
Old Oct 31, 2003 | 09:46 PM
b-stevens's Avatar
Alright thanks, I'll have to pick some of that up tomorrow
Old Nov 1, 2003 | 12:05 AM
ChickenScreamer94's Avatar
my car was like this too. I was trying to do the ICM spacing mod. I never got there b/c i broke my engine ground off and had to rig it back. I guess the pb blaster will work. I had a wrench on the lug and the stud and worked it for twenty minutes and still wouldnt budge! maybe youll have better luck...
Old Nov 1, 2003 | 12:54 PM
b-stevens's Avatar
so i went and bought some PB Blaster this morning, and ive been spraying it on every like 15 minutse or so and trying before i spray it... tapping it like it says on the bottle after it doesnt work and spraying some more... Its been sitting for at least an hour now... What should i do?
Old Nov 1, 2003 | 01:01 PM
Dave88LX's Avatar
Is that the ground on the bottom right of the engine? Mine was stuck too. I just snipped the damn thing and I'm going to put a new eye terminal on the wire.
Old Nov 1, 2003 | 01:03 PM
b-stevens's Avatar
Id rather not just start cutting stuff and replacing it...
Old Nov 1, 2003 | 01:13 PM
Dave88LX's Avatar
I hear ya, just meant it's not the end of the world if you have to put a new ring terminal on
Old Nov 1, 2003 | 01:17 PM
b-stevens's Avatar
I hear you on that one too but wouldnt that require some soldering? And once i just snip that off i would be able to just replace unscrew the stud and replace it? or am i wrong?
Old Nov 1, 2003 | 01:30 PM
buelldevil's Avatar
Try putting a wrench on it, and while holding presure on it tap it on top with a hammer. This works in most cases when using penatrating oils, and with screws and allen heads that are stuck.
Old Nov 1, 2003 | 01:38 PM
b-stevens's Avatar
I'll attempt the hammer and wrench idea, but if this doesnt work... what size thread is it and what size stud....and anything else ill need to know when getting replacements
Old Nov 1, 2003 | 01:48 PM
b-stevens's Avatar
hammer and wrench didnt work, what kind of stud do i need ie thread size, length, width, and whatever else i'll need to know
Old Nov 1, 2003 | 02:34 PM
b-stevens's Avatar
In the parts manual that i downloaded offline it says:
3-A12**2.183**STUD, IGN COIL (INBOARD)****94 F (LT1).. 1** 14057279
*************(STUD, HEX
*************3/8-16X.80-3/8-16X.80 300M
*************POR) (8.981)..........................
could i just go to like napa auto parts or something and ask them if they have a stud with those specs? Where is a place that would have these?
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Z Power
Sep 19, 2015 11:19 PM
tdigger9899
Sep 7, 2015 10:56 AM
