OptiSpark Life
Old Oct 31, 2003 | 07:00 PM
1FstFormulaV8's Avatar
OptiSpark Life
Hey. I just wanna know how what year your car is and how many miles it had when you had optispark failure.
1993 Pontiac Formula - Optispark failed last week. 70,000 miles.
My first opti failure.
Old Oct 31, 2003 | 07:11 PM
96 TA's Avatar
100,000 + some change on my opti. It's just starting to miss at low rpm's. It has been missing at high rpm's since 95,000
Old Oct 31, 2003 | 07:19 PM
ZZtop's Avatar
105,000 miles! I just changed mine cause my water pump was going bad. I didnt have any optu failure symptoms, but when I removed the old opti the input shaft was really lose, you could hear is rattle if you shook it too. SO, it was time for a new one.
Old Oct 31, 2003 | 08:36 PM
LT1 Bunny's Avatar
126,xxx and still going strong on the same opti!
Old Oct 31, 2003 | 09:17 PM
nader454's Avatar
Last week at the dragstrip, came home on a trailer, 93 z28, 82000 miles. Replaced opti with new delco, ran five minutes, died no spark. Replaced coil (15 bucks) still no spark. Now it tripped a code 41, ICM. Water pump was leaking so it needed it.
Old Oct 31, 2003 | 09:33 PM
CamaroBoy96Z28's Avatar
I replaced mine when my water pump went at 80,000 miles. Opti was still good, but wasnt taking any chances.
Old Oct 31, 2003 | 09:46 PM
RE AND CHERYL's Avatar
Cool
107K and runs great. Had the water pump off last month. I would have replaced it if any one had one in stock. Not readily available so I put it back on.
While I had it off I opened it up and took a look. Completely dry, no carbon tracks and looked great.
If it aint broke, don't fix it.
Old Nov 2, 2003 | 01:55 AM
revtime's Avatar
135k when my cap and rotor went bad.
Optical portion seemed fine but the bearing was a little loose.
Jeff1904
Jun 5, 2016 05:00 PM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
colts0455
Sep 27, 2015 01:07 PM
