valve lash
Old Nov 2, 2003 | 01:31 PM
Prorac1's Avatar
valve lash
What is the most accurate way to set the valve lash on our cars. We have done it running (so the lifters would pump up) and not running. Both ways (ya know, spin the pushrod till it dosent turn than a quater to half a turn) but neither seems real accurate. Any other suggestions would be appreciated. Thanks Prorac1
Old Nov 2, 2003 | 01:52 PM
94 CAMRO Z28's Avatar
The best way is to do it while the car is running. You want to back the nut off untill it starts to "tick", then tighten about 1/4 - 1/2 turn and lock the nut. Also, when doing it without the car running....0 lash is not when the pushrod doesn't turn any more, its when there is no up/down movement or play. If you have it to the point where you can't twist the pushrod, your probably slightly past 0 lash already.
Aaron
Old Nov 2, 2003 | 01:55 PM
Prorac1's Avatar
so did i go to far? should i just go till it stops ticking and forget about the quater to half a turn stuff? Thanks Prorac1
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
94Form
Jul 17, 2015 10:56 PM
