Finished Opti/Water Pump Install, my advice...
Old Oct 31, 2003 | 07:15 PM
ZZtop's Avatar
Be extremely careful removing the connector on the old opti! Mine was old and brittle and snapped in half. That jumper harness that attaches on the passenger side of the manifold is $121 from the dealer, even Jason Cromer is $72. Costly mistake! The install was a snap though, me and a buddy did it in 3 hours, the only snag was the broken sensor. Just thought I would share my bad experience with yall so you can avoid it.
Old Oct 31, 2003 | 08:21 PM
DarkRider's Avatar
Thanx Dog - Doin my opti install tommorow
Old Oct 31, 2003 | 09:15 PM
VeryBad's Avatar
That's good advice, as these are warm running engines that makes all the connectors brittle in time.
Gordon
http://www.witchhunter.com
WitchHunter Performance
Old Nov 1, 2003 | 11:00 AM
Fastbird93's Avatar
That tends to happen on these motors. If it's just the little locking piece that breaks, then you can still use the connector, just zip tie it in place instead of cutting and splicing a new connector in.
Old Nov 1, 2003 | 11:09 AM
rpm4lalo's Avatar
That little locking piece broke on mine during the install too.
Guess I better head out and zip tie it down, seems to have been okay for awhile but who knows maybe it has backed out a bit?
Old Nov 2, 2003 | 05:56 PM
ZZtop's Avatar
Mine snapped the entire top off the sensor, when popping the locking piece off.
Richardan15
May 30, 2015 08:36 AM
jayvar
Feb 2, 2015 10:00 PM
Collector Car
Jan 5, 2015 10:58 AM
ANDYZ28
Dec 29, 2014 09:13 PM
