Shoebox or anyone that can help. need to remove radiator.
Well I can do pretty much some stuff on the car but I want to know the easiest way to get this pos radiator out. I have been without a car for a week now
1st the ignition switch now a leaky radiator. Thanks CZ28
Just remove the 3 bolts holding on that radiator cap then remove the hoses and the fans (they slide out on clips) The radiator will just pull out, nothing really holds it in very well.. lol
After you get out the minor stuff...( intake duct ). Make sure you remove the transcooler lines and unplug the senor on the passenger side of the radiator. Take out the cooling fans and disconnect the hoses. If you got your car on a lift or can get it high enough its ez to remove from the bottom. If not your gonna have to do some wiggling as you slide it out at an angle. Its fairly simple dude.
good luck
good luck
Purchase a Haynes manual. Honestly, you should try to do some things before asking for help on something so easy to do. Our cars are not that hard to work on. Sorry if this comes off as a smart-*** remark, for no offense is intended.
Radiator removal is covered in my cam removal page. It's pretty much like everyone has said. Actually, I found it one of the harder things to deal with because of it's size, lack of working space and the effort required not to damage the thing.
Well its 9:53am and I just came inside from removing the damn thing!! Thanks alot for those that posted also thanks for jumping in Shoebox!! I had to take my shoes off and stand on the frame of the car in order to get the POS up and out!! Well I'm going to pick up the new one in about 2 hours and im going to check all the hoses and shyt for leaks while im out there and I will let everyone know how it turned out. I've been one week without my Z and Im ready to drive!
Victor Lamb
Aug 26, 2017 02:52 PM
SMO Q
Feb 11, 2015 07:13 AM
Vettenut97
Aug 15, 2001 08:21 AM
