Rocker Arms
Old Nov 1, 2003 | 07:57 PM
97RedSS's Avatar
Rocker Arms
I have a quick question about piston to valve clearance. I have a supercharged 383 with AFR stage 2 heads and a comp 224/236 .500/.521 114 (with 1.5 RR). I want to go with 1.65 rocker arms and was wondering if I will run into piston to valve clearance problems? Thanks in advance!
Old Nov 1, 2003 | 08:49 PM
Transamdriver's Avatar
If neither the heads or the block has been milled then you should be ok. It never hurt to verify though.
Old Nov 6, 2003 | 06:41 PM
97RedSS's Avatar
Talking
TTT!
Old Nov 6, 2003 | 07:09 PM
llafro's Avatar
I am running the 230/236 (.544 / .555 lift with 1.6 rockers) cam with stock heads milled 0.030 and an Impala head gasket (0.029 crushed thickness vs. 0.049 stock). I don't have any contact problems on a stock bottom end. If you are not sure, though, check it...
BRAD
Old Nov 6, 2003 | 07:12 PM
97 RedSS's Avatar
Nice name
Cody
Old Nov 6, 2003 | 07:39 PM
drewstealth's Avatar
And you both have 383 strokers.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
autoxr166
Sep 25, 2015 04:21 PM
Z Power
Sep 19, 2015 11:19 PM
