Wiring A/F Gauge
Old Oct 30, 2003 | 08:13 PM
Paul94Z28's Avatar
Wiring A/F Gauge
I have not messed with the wiring on these cars much. How would you recommend I wire in an A/F Gauge? If I go right to one of the O2 sensors, do I just splice in? I do not have any directons!
Thanks,
Paul
Old Oct 30, 2003 | 08:29 PM
blazzinbird's Avatar
ok the gauge has 3 wires red, black, and purple
red wire is a power wire, black wire is a ground wire, and the purple goes into the o2 sensor wire, so yes your splice that wire in the wire for the o2 sensor
Old Oct 31, 2003 | 02:15 PM
Not a good idea to cut or splice directly on the stainless steel sensor wires. Make your splice in the car's wiring harness, anywhere between the plug and the PCM. The wire you want is purple one on the passenger side (pin C8) or the purple/white on the driver's side (pin C20). A thought... connect both sensor wires to the poles of a single-pole/double-throw switch, and be able to read either side with the gauge.
Not a lot of info to be gained with the gauge... seems to be mostly for the entertainment value of the psychedelic light show
Old Oct 31, 2003 | 02:18 PM
Seal's Avatar
get one of those things that u can plug the o2 into, and the other connected for the a/f gauge...
Old Oct 31, 2003 | 05:47 PM
that is why you run 2 a/f gaiges in the car
Old Oct 31, 2003 | 07:21 PM
LOW TRAC's Avatar
Watch your self with that light show though. There have been a few times I've been caught at a light just sitting and staring at that thing.
Ohhhhhhhhh, pretty lights.
mattstrike
Mar 11, 2015 07:33 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Rich_z28
Aug 29, 2002 10:44 PM
$hawn
Aug 17, 2002 04:37 PM
