should i get zo6 maf?
Old Oct 30, 2003 | 11:22 PM
Seal's Avatar
ls1speed has a zo6 maf tuned for a LT1... its 150 bux... here is what it says
Bolt on up to 18hp in minutes! Specifically calibrated for your 94-97 LT1 powered F-body. Includes current 2001 ZO6 85mm Maf meter, sleeve, clamp and wiring harness adapter.
should I get it? think its worth 150 compared to G2's 350 price?
Old Oct 30, 2003 | 11:32 PM
Camaro_Maniac63's Avatar
Get it only if your stock MAF needs to be replaced since it is cheaper than a stocker. Otherwise, save your money for some real mods. Good luck.
Old Oct 30, 2003 | 11:34 PM
Seal's Avatar
what can be a good mod for 150 bux? :P
alot of ppl say save up and get LTs, but i'll be gettnig those after xmas so...
and I dont want gears at the moment
sende turkun demek, 3 kisi olduk
Old Oct 31, 2003 | 12:02 AM
Seal's Avatar
my best was 220 at 14.8 galons...
my 3.8 v6's best was 260 at 15 galons
both are combined highway/city with lots of stop and go
Old Oct 31, 2003 | 12:38 AM
MentalCaseOne's Avatar
Seal are you OK buddy?? Lay down, breath in....
Its gunna be Ok buddy.... the medics on their way... hang in there!!
Doc Doc! first he began to speak this weird language....
Then he totally flipped off-subject... I mean the man is way out there!! Can he be saved!!!
Old Oct 31, 2003 | 12:41 AM
madwolf's Avatar
Do yourself a favor and invest the money in something that won't make things worse.
The MAF sensor is one thing people shouldn't mess with at all.
Just my $0.02.
Old Oct 31, 2003 | 12:51 AM
DarkRider's Avatar
Just my $0.02.
I dont think you should just forget about one completely, take your time and get one for a good deal because they are expensive but have shown to free up usually around 10-15hp
Old Oct 31, 2003 | 12:53 AM
madwolf's Avatar
Well, everyone has their own opinion. My opinion is that they're a ripoff and total junk. Dyno proven NUMEROUS times.
Old Oct 31, 2003 | 12:58 AM
DarkRider's Avatar
most of my friends that have got one showed an 11 hp increase which is a rip off if you pay $350(GMAF)
but you're right I have seen dyno results where they didn't do ****
$100<yes
$100>no
Old Oct 31, 2003 | 01:02 AM
madwolf's Avatar
Well, I don't really care about the HP increase. The thing that bothers me is that most of these Z06, ported, GMAF and other similars act very funky. The air to fuel ratio is all over the place and it's very hard to get it right without knowing the actual calibration they have in there.
Old Oct 31, 2003 | 01:07 AM
FastWhiteTA's Avatar
Yeah come tune time WATCH OUT!
Old Oct 31, 2003 | 02:00 AM
DarkRider's Avatar
Is that only the Z06 maf or is that any aftermarket maf?
Old Oct 31, 2003 | 06:15 AM
97FormulaWS-6's Avatar
act very funky?? how?? and y would gm put a "funky" reading MAF on their flagship car?
I've NEVER had any problems with my GM Z06 MAF, but maybe that's the difference, I'm not using a LS1-speed version, I'm using a $85 GM version...
And I DO know the calibration... mine was interpolated directly from a '02 Z06 Vette PCM for the LT1 PCM.
next?
Old Oct 31, 2003 | 08:09 AM
Deadcarny's Avatar
with no experience on LS6 MAF's, madwolf hit this on the head for ported or aftrermarket MAF's. It is very hard to tune a car when they change this. To properly do it, you ahve to go in and play with the checksum and stuff, Which I do not even mess with..lol. I know I might benefit from a larger maf, but I am using just a descreened Stock LT1 unit and have no probs.at the most, I might try some larger ends in the future and see what happens that way.
Old Oct 31, 2003 | 08:16 AM
NVetro's Avatar
Madwolf is right. I am a victim of of the z06 maf tuning problem. My stock maf kicked the bucket, I did not want to spend $250 for a new stocker so I got the zo6 maf. I can tell you that the car does run alittle rich (you can smell it) but on a datamaster log it shows fine, within limits of good mixture and rich. If I could go back, I would spend the extra $100 and get the stock maf and keep it screened. The Zo6 MAF from ls1speed is screened btw if your curious. Have a FUN time getting that 85mm monster onto your CAI, I had to goto an fbodies favorite friend (Home Depot) to make it work Take Ion's advice, dont get it, save up for a better stocker, cus when it comes time to tune, and your A/F is all over the place (like me) then you will kick yourself for not spending the cash and getting the stocker.
