Driveshaft question
Old Nov 2, 2003 | 05:06 PM
gb95zconv's Avatar
Driveshaft question
On the u joint on the drive shaft is a little clip that bridges across the u joint and goes under the end of the c clips .....mine broke...is it really needed or can I install the shaft without the clip in place. TIA
Old Nov 2, 2003 | 05:12 PM
As I recall, the thin metal piece is there just to keep the caps secured when the driveshaft is not installed, so I think you should be ok without it.
Old Nov 2, 2003 | 05:18 PM
gb95zconv's Avatar
Thanks Rob, thats what I was thinking ...just wanted a second opinion. I put my olf steel shaft in after the 383 went in because I wasnt sure , but that damn thing vibrates like a **** at 90 mph and it has to go.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
blac94Z
15
Mar 2, 2015 12:00 PM
ddr698
Jan 31, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
